Wish I had (re)visited this thread before yesterday.
Had to go back in and reset (one) piston to align with the pad rivet, duh.
Luckily I had only done an around the block test before the bulb came on.
you only need to remove wheel and drop one caliper bolt to swing it down and rotate piston to correct orientation.
Just a refresher on basic points.
Saw I was near metal on a rear pad when rotating tires.
Wife is always hauling horses, pad was right there when I got parts and "a round tuit"
Wish I had measured rotors, they would have been fine to knock the rust off the edges last through another 60K, set of pads. original 18mm thick, wear limit 15mm, these were at 17mm after 60K
New bosch brand rotors fit well.
IF you live in the rust belt and rotor is a big fight to remove;
angle grinder a slot, a couple wacks on a chisel to finish splitting it, and rotor comes off easy peasy, no fight or BFH needed.
A chip dip container pushed into a paper towel over the open hub will keep crap out while working.
Use a fine file, lightly clean up the hub OD where the rotor goes, coat the surface with just a
little brake grease.
Oddly passenger side had plenty of pad life and the rotor came off almost TOO easy.
I think this at least partly a salt thing, the drivers side gets more salt sprayed in from passing vehicles , shrug
I did use new axle bolts and o-ring seal.
While you are in here; I highly recommend you clean up the ABS tone ring and pick up, mine were heavily coated with grease, brake dust, small wire brush, and paint thinner in a spritz bottle, blow out with shop air. Cheap preventive maintenance.
