We're getting rid of the propane oven / stove-top unit. One less thing to deal with (propane) and the oven was not great - took a long while to get to temperature, temps were really uneven and WAY inaccurate (using an separate thermometer). Also, since I added a microwave, this allows us to combine the microwave and oven with a GE 3-in-1 unit. FWIW, only two pizzas in the 3-in-1 so far and second one was better than any had been in the propane oven - and faster to cook. (Pizza is my reason to have an oven; cookies for my son and his wife. 🤷♀️ 🍪 🍕 )
So... that would leave us with just the one "burner" in our Duxtop induction cook-top... and I had to rebuild the galley anyway, so... moving back to a dual-burner unit (like we had in our Sprinter - which had no oven or microwave).
First, I searched a LOT for a 2-burner that would fit the 21-inch wide opening and there aren't a lot of options (on Amazon at least). I would have loved it if I could fit in a vertical unit, but they are just a bit too deep for the galley (less than 19" inside the rails - which I /could/ modify but would be a mess). The Empava unit has good ratings and feedback. Ordered this model and they sent the vertical unit instead. Tried again and they did it again. So I ordered a different Amazon link to the the same model and also ordered the True Induction unit - which was the same one we had in our Sprinter.
There are reviews of the Empava that say it doesn't go full power. And our experience with the True Induction was that it worked well but drew a LOT of power when it was "off" - forcing us to install a disconnect switch in the Sprinter so not to drain the batteries when it wasn't in use).
So when I got the correct Empava and True Induction, I did some tests for the background / "off" consumption and the max draw at "on." In a perfect world, I might have boiled an equal amount of water on each for comparison; but the output numbers said enough.
Empava
25W background
1kW max either side
Indicator for power on left shows 1800
Indicator for power on right shows 1300
Empava claims to be an 1800W unit. It is 1kW max.
Empava is so slick that the pan wants to slide off the unit.
True Induction
50w background
Coming back to update (11/1/2023): 2.5W background after it's "settled in"
1.4kW left
1.45kW right
Pan got noticeably HOT faster than the Empava.
True Induction painted bits have a little bit of "traction" to them and the pan stays in place better.
Duxtop
6W background
1.4kW max
Pan got hot about the same as True Induction.
Duxtop has similar "traction" to the True Induction.
If Duxtop made a 2-burner that fit, I would have gone with it for sure.
Empava
25W background
1kW max either side
True Induction
1.4kW left
1.45kW right
Duxtop
6W background
1.4kW max
