Status
Not open for further replies.
41 - 60 of 235 Posts
Discussion starter · #42 ·
List to date:
Stock size:
235/65/16, no modifications needed, fits in spare tire mount
245/75r16, no modifications needed, no info on spare tire mount
225/75R16, no modifications needed, no info on spare tire mount
255/70R16, no modifications needed, does not fit spare tire mount
235/85R16, modifications needed, does not fit spare tire mount
245/70R17, modifications needed, using 2.5" lift, fits in spare tire mount
255/70/16, no modifications reported (?), no rubbing, no info on spare tire mount
265/70-17, modifications needed, using 3" lift, no info on spare tire mount
(note: load rating depends on brand and model of tire, sizes will be the same regardless of brand in most cases, so I did not include the load rating or brand in the summary)
Save
245/75-16 Definitely needed the pinch weld folded down/ trimmed. (i folded mine down with the help of a small sledge) and the bottom corners of the plastic bumper piece needed a slight haircut. No idea about the spare, i don't go anywhere that the Triple A guy couldn't get to lol
This was for Falken Wildpeak A/T's. I've heard that a less aggressive tread may not need trimming, but without trimming, i do think they would eventually rub somewhere (driveways, bumps etc..)
Discussion starter · #44 ·
NEW INFO: tire radius in inches
List to date:
Stock size:
235/65/16, no modifications needed, fits in spare tire mount (28)
225/75R16, no modifications needed, no info on spare tire mount (29.3)
245/70R17, modifications needed, using 2.5" lift, fits in spare tire mount (29.5)
255/70R16, no modifications needed, does not fit spare tire mount (30.1)
215/85R16 (no info) (30.4)
245/75r16, no modifications needed, no info on spare tire mount (some report modifications needed) (30.5)
265/70-17, modifications needed, using 3" lift, no info on spare tire mount (30.6)
235/85R16, modifications needed, does not fit spare tire mount (31.7)
(modifications = cutting or removing part of body or trim)
(note: info shared on this list is supplied by forum members, not my own experience or measurements. there is some conflicting info)
Just to add.
I have the 245/75 ltx tires. Made no mods but it does slightly rub at full lock (even after slight trimming of the mudguard and a little hammer work on the pinch weld).
In getting bigger tires I tried to match the section of the original tires to maintain flotation in sand. The section for this tire is 7.5", the stock tire is 7.9".
My spare is lowered about 1" due to water tanks. It fits (very closely) if it is pulled back as far as possible when raised.
It seems there is some body variation since others report more significant issues.
T350 148"
I have LT225/75R16, no problems with rubbing even at extream turns or angles. Only problem is speedometer error which you will experiance with any tire change due to the diameter of the tires on the stock rims. More than likely you will be going faster than the speedometer indicates, and your odometer readings will be different.
Was there ever a consensus on SWB/LWB/EXT spare mount space? I know my LWB has a heatshield that the spare is tucked up against that I noticed the EXT does not have.
Thanks for making the thread Surly Bill! I will use it for wheel well info but I think I will have to do my own measurements for the spare before I start shopping!
(Oh and I should probably wait for my check to come in the mail too... pesky government shutdown...)
255/70R16 does fit in spare tire on LWB
List to date:
Stock size:
I just got the 255/70R16 at Discount Tire. To my surprise, the spare tire mount can accommodate this size wheel at full 70 PSI. I was surprised, pleasantly.
Discussion starter · #51 ·
NEW INFO: update on 255/70/16 regarding spare tire
List to date:
Stock size:
235/65/16, no modifications needed, fits in spare tire mount (28")
225/75R16, no modifications needed, no info on spare tire mount (29.3")
245/70R17, modifications needed, using 2.5" lift, fits in spare tire mount (29.5")
255/70R16, no modifications needed, does fit spare tire mount (30.1")
245/75r16, no modifications needed, no info on spare tire mount (some report modifications needed) (30.5")
265/70-17, modifications needed, using 3" lift, no info on spare tire mount (30.6")
235/85R16, modifications needed, does not fit spare tire mount (31.7")
Save
cWhat KO2 tires can be installed on factory wheels?
Tire Size, Load Index & Speed Rating Rim Width Range (Min/Max) Section Width on Measuring Rim Width Overall Diameter Max Load, Single (lb @ PSI) Tire Weight Buy Link
LT255/70R16/E 120 S 6.5″ – 8″ 10.2″ on 7.5″ 30″ 3085@80 47.7 amzn.to/2yvGLGG
LT225/75R16/E 115 S 6″ – 7″ 8.8″ on 6″ 29.2″ 2680@80 42.4 amzn.to/2R6qeQq
*LT245/75R16/E 120 S 6.5″ – 8″ 9.8″ on 7″ 30.4″ 3042@80 48.9 amzn.to/2R9TZzK
I just bought 5 Michelin LTX A/T2 245/75R16:
Didn't actually drive them, b/c I have my Nokian WRC3 225/75 on right now. I need to take off my Weathertech front mudflaps. I also have the Foes 2" lift coming. Hoping the Michelins won't require any mods after the lift.
Full size spare needed to be deflated to fit underneath. Also, make sure you can lift your spare all the way up, so there's no exposed cable. I had my first spare wheel stolen b/c someone cut the cable (think the spare was mounted upside down).
w/o mudflaps. Anyone need any front mudflaps?
Reactions: Deano
Save
Just tried the BFG K/O2's 255/70/16 on my 2018 148" HR 350ext, they weren't even close on fit? Rubbed on front bumper and pinch weld with the wheel straight, didn't even bother trying to turn the steering wheel to see if they'd hit, strange how this tire fits for some. Gonna try 225/75/16's, lose a bit of my load rating, but still sit at 10000lbs at 80psi.
Colin
Save
Discussion starter · #58 ·
All of the above fits should be qualified by which length vans.
Is there a wheel well size difference between the 148 and 130?
As far as I know, it's the same for 130, 148 and 148el.
It's possible the 150, 250 and 350 could have different suspension height, but that would not affect what size tire fits; the tight spots are fore and aft, not above.
Save
Discussion starter · #59 ·
Ghostshaper; Yes, 245/75-16 is already on the list.
Thanks for sharing.
Reactions: Ghostshaper
Save
BFG K02 in 245/75r16 on Ultra 450SB wheels rub front pinch weld a lot. Pinch weld has to be folded or cut off. I did just that and they are fine now. 2019 T250 HR 148".
Status
You have insufficient privileges to reply here.
