Does the ground cable need to be at least the same size of the other wires in the system?
I have AWG 2/0 between the battery terminals and the bus bars. It might be overkill for my system, but I wanted to allow for future expansion.
My electrical cabinet is located behind the drivers seat. I plan on wiring AWG4 from the negative bus bar to the factory approved grounding point near the e-brake (about 8 ft away).
In addition, I'm grounding the inverter with AWG 8 (as specified in the manual) to an approved grounding point behind the left rear wheel well (about 8 ft away). The inverter is connected to the bus bar with AWG 2.
