Thought I'd be the one to start the "official" MPG for the 3.2 thread. Try to post your numbers and note which rear end gear ratio you have. Also please note the total mileage on your van....
Great post. Don't give him a fish, teach him to fish.Here is something I look at for tow vehicle engine and drivetrain selection.
I like to travel between 65 and 70 mph when towing. So at what RPM power and efficiency range, in 6th gear, will my engine be turning, at that speed?
With a 3.31 ratio the ecoboost might be at, say 1800 rpm. I would consider that lower than optimum for the aero and mass load of a trailer at 65 mph. With the 3.73, the RPM might be closer to 2000.
Based on the HP and torque curves of the 3.5, I would conclude that the 3.73 would be my preferred choice for towing at my preferred speed.
My 3.73 3.2D is just a hair above 2000 at 65 mph, where I usually tow.With a 3.31 ratio the ecoboost might be at, say 1800 rpm. I would consider that lower than optimum for the aero and mass load of a trailer at 65 mph. With the 3.73, the RPM might be closer to 2000.
Tks Whitedog. I don't do likes often either, but have to say it feels good to get one!Great post. Don't give him a fish, teach him to fish.
(Edit: This is why I don't do likes. If I had just given a Like, it doesn't explain WHY I liked it.)
I read your post a few times and think I get it. I was surprised at the almost 7000# curb weight of the DRW wagon. The seats and interior trim add up fast.SilentlySoaring,
I found the MPG difference between the SRW 3.31LS Rear, 12 pax wagon at 20.08 MPG vs. the DRW 3.73LS Rear, 15 pax wagon at 19.29 MPG to not be that significant.
However, according to the 2015 Transit Product Information Book, page 15, which deals with the wagon version, the capacities are as follows:
350HD DRW - High Roof / Long EL wheelbase @ 148" / 3.2L Max payload of 3,340# / base curb weight of 6,941# / GVWR of 10,360#
350 SRW - High Roof / Long wheelbase @ 148" / 3.2L Max payload of 2,750# / base curb weight of 6,432# / GVWR of 9,250#
Max towing capacity, 3.2LPS / 148 SRW / 3.31 rear => 10,600# GCWR / 4,000# max trailer towing
Max towing capacity, 3.2LPS / 148 SRW / 3.73 rear => 11,200# GCWR / 4,600# max trailer towing
Max towing capacity, 3.5LEB / 148 SRW / 3.31 or 3.73 => 11,200# GCWR / 4,800# max trailer towing
Max towing capacity, 3.2LPS / 148 DRW / 3.31 rear => 10,600# GCWR / 3,100# max trailer towing
Max towing capacity, 3.2LPS / 148 DRW / 3.73 rear => 11,200# GCWR / 3,700# max trailer towing
Max towiing capacity, 3.5LEB / 148 DRW / 3.73 or 4.10 => 11,200# GCWR / 4,100# max trailer towing
So as you can see the MPG difference between the SWR & DRW were within 1 MPG, but the towing capacity is 900# more with the SRW over the DRW.
Even going up & down the hills of western MD & PA, the diesel had more than enough torque & power to travel uphill, fully loaded with pax at 65 MPH plus and still maintain speed and have reserve power to pass the big rigs and slower cars going uphill. With the proper hitch and controller, I'm sure the use of the tow/haul option would make hauling the trailer a breeze.
The comparison in TXaggies' post was for an EL DRW at 6,941 to an L SRW at 6,432.I was surprised at the almost 7000# curb weight of the DRW wagon. The seats and interior trim add up fast.
I know I'm off topic just a little, but just to chime in, because I think I've probably got one of the most highly-achievable examples of what a Ford Ecoboost in 1/2-ton duty utility can do. I've got an aluminum F150XL, reg cab, 2wd, short bed with 3.31 rear axle, and the new 2.7 EB. At less than 4200 lbs of curb weight, in the highest gearing and smallest configuration, driving as conservatively as possible w/o hypermiling, in mostly 45-65 mph state highway commutes with little traffic, running regular E10 gasoline, I am so far averaging 23.6 on fuelly, but when I take out 65 mph highway trips, I'm likely going to come in around 22.5 mpg lifetime in this truck.everyone is free to make their own overall conclusion on turbo diesel vs turbo gas. i think many folks were surprised to see the decent actual mpg for the 3.5 EB transit since the real world mpg for the F150 version has been pretty poor, as thousands of owners will tell you. with moderately boosted gas engines, the hiway mpg can be good if you're the type of driver who is good at keeping it out of the boost range...but when towing or even just driving into a headwind it can drop significantly.
Direct injection gas engines, as a 'category', have all kinds of issues as you know. Personally I'm hopeful that the 2.7 ecoboost (which I don't own, but considered buying) solved those issues but it's hard to say at this point. My point is that you are categorically proposing that 'all' post 2007 diesels have an inherent issue.
In comparison with the EcoBoost option, the diesel is "only" ~$2,000.00 more, a little less if you order the dual battery option with the gas engine.I'm a huge diesel-power fan and have needed a truck for years and came to read this thread, because I've always wished for a Euro-style van configured as a truck with a cab chassis and one of those Euro-styled drop side bodies with a 6 cylinder diesel, but configuring a truck this way in the U.S. would be financially ludicrous but still follow the Euro vans like the transit with diesel just to satisfy my interest.
Premium was not required in my F150 FX4. They recommended Mid-Grade.Doesn't the ecoboost require premium gas?
What kind of load, what kind of driving?350 HD long and tall dually with the 3.73 limited slip.
hand calculated for the first 3 fill-ups to date
17.5
17.0
18.9
I'll take that all year long !
