Is anyone hauling kayaks on roof along with solar panels?
34K views 32 replies 16 participants last post by  shizzle
#1 ·
Hey all,
I am struggling with a good solution to carrying 2 - 12 ft. kayaks on top of a 148” medium height roof, along with a Maxxair fan (mounted at back) and eventually installing solar. Currently, I have no roof rack system but the fan is installed. I know that I will need some sort of rack system to mount solar (hopefully soon) and figure this would be a good time to plan for a potential “dual” use (both solar and kayak) rack, if feasible. While I am not thrilled with the idea of having to load a kayak up that high (and needing to have a ladder), I figure it won’t be so bad since we likely won’t be taking the kayaks along all that often. The other alternative would be a trailer, which I would like to avoid if possible. Although it may turn out to be the better option.
I know there are a ton of different roof rack solutions, but would be interested is seeing pictures from anyone hauling kayaks on the roof along with solar panels? Just searching for ideas….
#2 ·
I just downsized my 16-foot kayak to an 11-footer so that I could carry it in the cargo area. I cringed at the idea of having to load a 16-footer on a roof rack on top of my medium roof van. Your 12-footers should fit in the cargo area, but I'm guessing that's not an option for you as you may have a wagon or converted cargo van (?). I like your idea of a specialized trailer; much easier to load and unload than a roof rack. Keep in mind that the harder it is to transport your kayaks, the less you'll use them.
#3 ·
Reactions: markley
#4 ·
I haul my kayaks on the roof, and have a Maxxair fan and 2 100W Renogy solar panels on front. I use a Thule rack system and have a set up of 3 bars for the kayaks, and 2 bars for the solar panels.
I'm not a fan of hauling kayaks on the roof. It's such a pain to get them up there and tied on. I try hard not to walk on the roof but it's nigh impossible to not make some errant steps.
I strongly recommend a trailer. Save your self and your roof. Use the extra space up there for more solar.
#5 ·
There's no easy answer...a buddy is thinking of a low roof for the reason of loading boats, much as I try to convince him he will be kicking himself for not getting at least a mid roof.
Ideally I'd have a ladder and a walk-on roof. At one point I nearly killed my friend trying to load a 17' canoe on my bare-bones roof/solar rack...
The other option if you're lucky enough to have a high-roof is to suspend the boat from the ceiling...
#6 ·
Have you ever seen a Thule Hullavator? Expensive - but incredibly easy to operate (I have friends who use one for their tandem kayak)
That being said - I've been pulling kayaks around with a 12' utility trailer for a decade or so. I've had as many as 9 on board; or a crazy assortment of boats/bikes/gear. My Touring Snowmobile also fits on the trailer. I had a "second story" fabbed at our local steel shop - it lets me haul my 16 sea kayak just fine. I've never had a problem finding a place to park a large SUV and trailer at even our most rustic boat launches - and it's a LOT easier on your back to not be lifting kayaks over your head.
#10 ·
The Hullavator is an intriguing option..seems like the easiest option to store on top since all of the strapping can be done without having to get on the roof. Although, it looks like it may be difficult to pull both handles at the same time to get the boats down (would need a ladder to get started at least). All other roof options would seem to require getting up there to strap the boats down, which would mean I would need a roof system that we can walk on. I like the Aluminess roof platforms...but jeeeshh that cost.
Also, I like your trailer setup! I was thinking an 8 ft trailer would work, but you have me rethinking that.
#7 ·
I wouldn't want to put boats up there. Would probably go trailer if I needed to haul more than the one 14 footer I haul under my passenger seat and bed.
You may not be aware of this, it's so expensive and rarely seen... there is a tilting, winch loading roof rack system that some Class C and Class A motor homes use for kayak transport. About 3 grand, as I recall.
#11 ·
We got an Aluminess rack with a ladder on the side with the intention of adding solar panels in the future. Had the optional cross bars installed to carry a canoe. With a canoe it's a two person job but fairly easy. Of course I'm 6'-5" and it's a nice light kevlar canoe so handing the canoe up to somebody on the roof is fairly easy. May get more difficult once solar panels are installed to move around on the roof.
For a kayak I could envision a solution with a kayak rack off to the side using the rack ladder, but that would only allow for one kayak.
#13 · (Edited)
Hmmm..yeah, that optional cross bar sits up nice and high above where solar would be mounted. Seems like a nice option. So how do you like the Aluminess rack? Seems like that and a ladder would be doable....although both my wife and I are around 5'6. I like the idea of the platform which could allow for some additional storage as well.
#12 ·
And another thought (although maybe it doesn't make as much difference on something as big as a full-sized van) - I was astounded at the hit in mpg with a kayak on the roof of my V-6 Ford Escape. Just having crossbars in place (no boat) reduced the mpg by 1 or 2..... the trailer, which is wider than an Escape, didn't seem to make much difference.
#17 ·
I think it depends.
Having a roof rack for kayaks, rafts, bikes and general stuff was important to us. I left one bay open for a 150 watt solar panel. That's not enough. If you get enough solar panels to make a difference, you're going to be loading and unloading boats over your panels and you're going to need to thread straps or ropes for tie down. That's a problem waiting to happen.
Get a trailer. (I also have a trailer.)
Reactions: markley
#19 · (Edited)
We think the Aluminess set up is great. The crossbars are easily removable and you can specify the height that you want. I believe ours are a 5" lift. In reality it is hard to measure the curvature of canoe gunnels on your own, so I think in hindsight it could've been reduced a couple inches and still not have issues with future solar panels, etc. You'd have to figure based on your kayaks and how they are to be mounted.
With just the rack I haven't noted that much of a mileage drop. Though to be honest I didn't systematically track it prior to the rack or with the rack installed. Just anecdotally and resetting the trip computer for each road trip, maybe 1 mpg (???) drop with the rack on. With the canoe if I recall perhaps a 3 mpg drop. But don't take my numbers as gospel by any means.
As an aside I've only carried the canoe once on my Subaru Outback Sport (Impreza) and the gas mileage seemed to improve, so perhaps there is an aerodynamic benefit to having an upside down boat on certain vehicles.
#24 ·
Finally found a solution to getting our kayaks on the roof. Mounted Yakima towers and 70 inch bars to 80/20 side rails, telescoping ladder, and use a rhino rack side load bar. Surprisingly easy to get on and off..at least with two of us. Also can still open roof vent!
Sent from my SM-G950U using Tapatalk
#25 · (Edited)
This is great. Thanks for posting. Two related questions:
1) What length telescoping ladder did you get?
2) I'd like to carry our two sea kayaks as well, with solar, but I have the high roof. How much more trouble do you think that would be? The much higher roof and 17-foot boats?
Much thanks.
#29 ·
Check out this vid. Guy on his own putting up a 15+ foot sea kayak on the roof. Good system.
https://www.youtube.com/watch?v=MUcd8lCZNVo
That's the same yakima extension bar and cradles that I tried with mine while trying to finger this out...2 ladders and a lot of back and forth...works but...
I now use a small boat trailer...14' galv eazy-loader with bunks...much cheaper than a specialty Kayak trailer...paid $200 on CL...The boats stay on the trailer (covered and pre-loaded w/ gear) and are always ready to go...16' & 18' just fit w/ minimal overhang front/rear...changing things up to use the 16' canoe takes minutes...
Reactions: dray2009
#32 ·
My Solution
We often haul two kayaks and needed a solution for the roof of our 148" medium roof Transit. I fabricated a roof rack out of Unistrut and attached J-Bar kayak racks to it. Works great even with the Dometic AC on the roof and still have room for a future fan and solar panel. The rack is not completely finished; we had some kayaking to do! Right now we're using a step ladder to get them up there, but will eventually add a ladder to the back door.
