Fiamma Awnings
53K views 45 replies 17 participants last post by  belloinsella
#1 ·
One of the things I'd like to add soon is an awning. So far I haven't been able to locate a bracket that is a direct mount to the factory threaded holes in the roof, though it looks like this generic Fiamma mount could be modified to work:
http://fiamma.com/download/installation_adapter/98655-316.pdf
Anyone else done any research on this?
JP
#3 · (Edited)
I am also interested in an awning and base plates which could use the roof's pre-threaded holes. This new thread is focused on removable roof racks:
http://www.fordtransitusaforum.com/accessories-add-ons/10706-racks-removable-kayaks-bikes-etc.html
but ideally an awning could also be removable for seasonal use on my low roof Wagon?
Has either of you emailed Fiamma about the new Transit? I am waiting to hear back from Yakima . . .
JP4
I'll be installing a Fiamma Awning as well at some point, here is a link with the different adapters. There's two pages tho.
Not sure yet which one will work, but check it out.
http://www.fiammausa.com/products/awnings.asp?Fam=A2
#4 ·
Emailed fiamma in regards to this will hopefully hear something after the weekend
Reactions: PeterR
#5 ·
looks like they have a mount that will work for the high roof. Here is the email I received today:
"As of now we do not have any brackets to fit any of low or mid roof Ford Transits. We do have a bracket to fit an awning on the side of the high roof Ford transit."
I asked for the model number and if this bracket needs new hole drilled in the van. Im assuming so..
Reactions: PeterR
#6 · (Edited)
Thanks could you post a link for the new bracket and base plate if any when you get it? Thank you. The Fiamma links earlier in this thread show other existing set ups.
#9 · (Edited)
#10 ·
I have been planning on a different brand, the Carefree Freedom.
While they have a Sprinter roof mount, I don't think they have a roof mount specifically designed for the Transit rail spacings.
We'd be doing a wall mount 4M acrylic non-motorized unit.
http://www.carefreeofcolorado.com/products/freedom-wall-mount.html
and likely ordering from Scotty's in FL.
http://www.scottiescatalog.com/Freedom-40M-Acrylic-Wall-Mount-Awning-FreedomAW40.htm
I think that it's roughly comparable to the Fiamma, but somewhat cheaper.
On the trailer that Annie is replacing, I installed one of Carefree's slide-out topper awnings. Seemed fine.
Just throwing this out as a possible alternative.0:)
I hope that no one has had bad experiences with them!
#12 ·
Bump. Thinking about this setup with either Thule (Thule Podium Foot 460 with fit kit 3138) or Ford Factory Rack and ARB Awning mount kit to attach a Fiamma F45S.
Fiamma F45S 300 (Black case/gray canvass)
http://www.fiamma.com/EN/products/fiammastore/wall_winch_awnings/f45_s/
Thule foot #460
http://www.rei.com/product/816719/t...=cse_PLA_GOOG-_-8167190001&CAWELAID=120217890000759558&lsft=cm_mmc:cse_PLA_GOOG
Thule Base 3138
http://www.rei.com/product/772689/t...=cse_PLA_GOOG-_-7726890046&CAWELAID=120217890000777828&lsft=cm_mmc:cse_PLA_GOOG
ARB Mounts
http://www.4wheelparts.com/Awning-Bracket-Mounting-Kit.aspx?t_pn=ARBOS3071
The rest of the rack space would be devoted to 2x 130 watt solar panels. Anyone have experence mounting fiamma to standard bar set?
#13 ·
I will be mounting a 11'6" Fiamma on my High roof Transit....
It was raining this weekend camping and it would have come in handy to keep direct rain off the ground which then tracks wet mud into the van. Also need to keep hot sun off the open slider to keep the interior and dog cooler.
I will be using the simple side mounting plates (which I've already ordered) from Fiamma but can't install them until I purchase the awning because the mounting locations are distinct, and for some reason I can't get the installation instructions from the manufacturer. (They apparently make each unit to order)....a bit exasperating because my upper cabinets are complete and I would have to remove them to install the awning.
That will be my next big purchase...
#16 ·
Interesting....It appeared intuitively to be able to slide the mounting point along the track, which is consistent with your post Robert. The Fiamma apparently has a "zone" on either end of the housing/ track within which the outer mounting brackets (of 3) need to be mounted. I am not able to get the exact dimensions of what these zones are in contacting Fiamma USA.
Do you have any info on how far from each end the mounting plates can be mounted? What is the "play" in the mounting locations?
#17 ·
I have 5 mounting points the ends are about 6 inches in and the others spread out along the middle. There's nothing inside the track that would suggest one point over another. Minus the awning it's just a hollow extrusion. Use common sense, spread the load and you'll be fine.
#20 ·
Subscribed!
I will be installing a Fiamma F45S 350 with the Fiamma brackets in a few months when i receive the Transit (High Roof Extended length). If anyone has installation pictures this would be great!
I will post mine when the job is done.
#24 ·
Installed my fiamma F45s w/ Thule Bars/podiums, ARB Awning Mounts, and the Fiamma wall mount kit.
Noticed you have the Thule 460 feet and square bars. What did you use to fasten the feet to the van? Were those bolts included with the kit? How did you seal the feet to the roof? Can the bars be removed leaving just the feet in place?
#22 ·
That's a nice-looking van, overall. I think we've seen it before, with the window install.
I'm expecting to put a rail up top, and just attach cheap tarps. One thing I'm looking at, is having it extend all the way to (or a little past) the front of the sliding door... to have full rain coverage for an open door. That would be 30 or 32 inches of unsupported rail! -- or, in your case, awning case. I expect that you were limited by instructions, on how far from the end the support could be. Curious, though -- do you think the case is rigid enough to slide it forward the remaining 12 or 18 inches?
#23 ·
Thanks EddieZ. The factory recommended attachment points are at both ends and the center. As mine is built, I'm already ~6" inside (behind) the front end. Not sure I'd be comfortable extending it further forward than that and it would protrude forward past the front roof angle by quite a ways (think jousting...).
If you want it that far forward, maybe consider direct mount to the wall, you'd be able to go lower and further forward. I just didnt want to drill into the side of the van.
#25 ·
The Thule foot kits come with mounting hardware to bolt into to factory platform & threaded attachment points. I used RTV silicone to seal between van and foot. However, the kit comes with a pretty good rubber pad that may have sealed on its own, RTV is added insurance for good long-lived seal.
As for removal, the foot kit comes in two pieces, the van attachment "foot" and a tower/bar section. The tower/bar section can be removed via 2 allen bolts per tower. The remaining foot would remain attached to van and sealed. This would be a bit of a PITA, in my opinion. If you're looking to frequently take rack off, maybe contact Thule and see if they have a diff't tower that has a quick release mechanism.
#26 ·
Our Installation
We installed a Fiamma F45S awning, which is installed on the side of the van just above the door (i believe only the High-Roof has some room to do this).
It looks like a solid product and the color match the Magnetic Grey of the Transit :)
Here is the story:
http://faroutride.com/fiamma-f45s-awning-installation/
#27 ·
We installed a Carefree, which appears to be a very similar design to the Fiamma. Mainly because we wanted an acrylic, not vinyl, awning. It looked like acrylic wasn't available with the Fiamma.
We have some issues with the Carefree build quality (and shipping competence), but nothing we could not handle.
The install process was very similar to atoine's. However, we did use plywood backers on the inside to distribute the awning weight and the bolt tie-down and torque forces. We also used VHB instead of the anti-erosion tape, and built up the front mounting plate with aluminum stock instead of spacer washers.
Then potted as appropriate with non-sag lap sealant.
Here's the link to the details:
http://anniebuild.blogspot.com/2015/07/mawnings-spent-installing-awning.html
#28 ·
I am wanting to order a Fiamma F45s. I have emailed them 3 times over the last 2 days. I have not received a reply. I always have a hard time spending $1100 without having a freeking phone number I can call if there is a issue..
Anyone else have a hard time making contact with them?
Smitty
#29 ·
Some years ago, I needed parts for a Fiamma F35 and had similar difficulties contacting the Florida-based office. Instead of e-mail, I called. Everyone was very helpful when you were able to talk to them in person.
Regards,
EJB
#30 ·
That number, by the way, was 407-672-0091
Reactions: smitty141
#31 ·
FIAMMA 11'-6" TITANIUM awning
Using factory plates on my high roof, here is the awning in the field....
very satisfied with the quality of this awning. Installation was a challenge dealing with the curve of the Transit. Had to fashion custom aluminum shims for the front bracket....plus the thing has to be dead straight (all three brackets) and plum in the x,y,z, directions or the thing won't work. Be prepared to spend 3x more time than you think to install this and say a hail mary once you decide to drill the holes....and hope the bracket align perfectly once you prop it up there....
then I had to fashion some custom installation for the strut clips at the bottom to secure and hold up the end load...
#34 ·
length
Hard to say which length will work for you.
You may want to determine the length based on the connection points and where you can drill holes (from the interior). There are logical places to create the connections based on the inner and outer wall bracing points. Check that out. You might not have a choice for one or the other given the existing van limitations
