I have finally found some time to begin working on my conversion! Installed a Maxxair fan and backup camera this weekend, as well as ‘mocked’ up my van layout using cardboard. I am now ready to start on the floor. I realize that subflooring has been extensively talked about on this forum, but after my searching around I still have some questions. In order to save headroom (can currently stand in MR with a few inches to spare) I have decided to go with ½ inch plywood on top of floor ribs (followed my underlayment then flooring- either vinyl or cork). What I am undecided about is what to use between the ribs under the plywood. I have seen that most folks use ½ polyiso or plywood, both of which are slightly thicker than the height of the ribs. To me, this seems to defeat the purpose of having a level surface to lay the subfloor on. Maybe the foam board will compress some to “even out”? I have also seen where someone has cut 2x4’s to the exact height of the rib (3/8”?). This just seems like too much work. Does anyone know of something (wood, plastic, etc.) that is the exact height of the rib?
I am really not concerned of the insulating properties below the subfloor and do not plan on screwing the plywood down (will likely bolt down using tie downs). However it seems as though I will need something between the ribs in order to prevent warping, especially between the wider gaps of the ribbing.
