I am confused as all get out on selecting ANL fuses for my build. Here are a couple of examples, which I am sure there is a formula that once I learn it will solve my problems.
Battery Bank-400 Amp Hours 12 V LiFePo4 connected into a Victron Lynx Distributor. So, I can buy a 600 Amp Fuse ANL fuse, but it looks like that is 32V. Is this like a straight wattage conversion? Meaning 400A*12V=4800 watts. I have read that the fuse should be 1.5 times the max output of the load, so 600A*32V=19,200 watts, or is the correct size like 225 Amps? Can someone give me some guidance here?
