Spent some time last week working on the first bit of installed furniture, if you will. We planned an East-West bed platform as part of our permanent configuration, and getting the bed off the floor immediately gets us back about 30 square feet of space.
Starting off with a couple sheets of 1/2" ply from the local big box store. The final build will be done with Baltic birch, this is long term temporary stuff.
Got it all broken down and rough cut, and commenced adding lightness. I'd love to have a 5x10' CNC router like my buddy up in Eastern Washington, but this will do for now.
Pieces all made up and dry fit. I'm used to building with 3/4" material for house cabinets, so this feels incredibly delicate until it all comes together.
Flat surface disease immediately kicks in.
And done (ish). Added a bit too much lightness, the structure felt rather flexible when I sat in the center, so added a set of legs underneath to support things for now. Picking up a mattress this evening and will be spending most of the week camping in the van while on the road for a work trip.
Also rolled out our new floor, a VanTred cargo mat. The Ford OEM floor is a thin plastic/rubber sheet with felt backing, and it was already getting manky. This is more an open cell foam material with a fairly durable top layer, and it fit perfectly once we let it unroll in the heat for a day.
Finally, pulled the drivers' seat and installed the other swivel. This one was a bit more involved than the passenger seat, due to the dual batteries that live underneath it. There's a plastic cover that needed a new hole to pass the seat electrical connections through, and a battery retaining bracket that gets deleted, since the swivel base is flat and will hold down the battery cover quite nicely on it's own.
Under the seat pedestal. There's a lot going on in here, and dropping a steel plate across 1300 CCA of batteries would make for a very bad day. The box at the rear of the enclosure holds the fuses for the customer connection points, and the pre-wired auxiliary circuit plugs. The two studs at the lower left are the Customer Connection Points (CCP from now on) 1 and 2. CCP1 is fused for 60 amps, CCP2 is fused for 175 amps, and the van monitors load on those circuits as well as battery voltage. They stay hot anywhere from 30-60 minutes after shutting off the van, and are protected from drawing down the AGM's below a safe restart voltage. I'll be connecting most of the van-powered auxiliaries to these points. CCP2 will be dedicated to a 1200w inverter that will eventually be my "generator" input to the real electrical system, and CCP1 will power everything else. Air compressor, exterior lights, any other 12v loads I want powered only while the van is running.
Had to trim the back of the slide rails a bit to clear the door plastic when it swivels, discovered after scratching it pretty good on the first rotation.
And done. Now there are two good seats in the living room!
