Hi all, haven't seen this posted here yet, a pretty good review by a salesperson who is knowledgeable about the van.
https://www.youtube.com/watch?v=blI5mVxWDj8
Pictures of high roof van show the side slide door to be the same as that on middle roof vans. If it extended all the way up it would interfere with roof curvature unless door was rounded off at top. Having said that, the middle roof van side slide door is much taller than the low roof van. I don't see how a person in a wheelchair could hit the top of the door opening......cut......
Has anyone seen a high roof? Be real interested in the slider opening.
Looks like in this video that the slider height, is the same as a low roof. Hoping the high roof has a taller slider, so won't have to be ducking to avoid hitting my headwhile entering in wheelchair.
Any observations will be appreciated.
Semper Fi
That is the opening itself, not floor to roof.Dale, is that 63" the height of the door opening? Or the roof top off of the floor.
Definitely worth checking but I think you'll find that to be the 63 inch dimension. Please let us know what you confirm.Chance,
.....cut.....
If someone has a chance to look at a medium or high roof, would appreciate the height of the door opening above the level floor area.
Semper Fi
I measured but didn't write it down. My recollection is the top of the windows are around 56" - about an inch higher than Promaster. That's tall enough for someone seated in a powerchair but definitely not a standing person.... would like windows I can see the horizon while standing inside the van. With Transit I fear I'd be looking at ground because my line of sight is well above 60 inches or so...
