I got my transit used. How do i reset it and get it using a code i know?
Hey asdrew, just recently picked up a keyless entry keypad. The included instructions were not particularly inclusive regarding the exact process specific to the Transit for programming the suite of keyfobs and keypad. Several attempts with a variety of web based "help" has resulted in confusion (and no solution). Any good links to a true answer?[/QUOTE]You can, at least, still use the keypad to lock the doors by programming all your keyfobs and other keypads at the same time.
For some reason I have found 4, 6, or 8 sequences as magic numbers- also ending with the key off as well as on. Sometimes you get it right the first time, others after a few tries. The last one I did on my 2018 took a while to get it into chime mode, I think some of the tries were too fast off/on and others were too slow....3) Turn the key from OFF to RUN 4 times ending on OFF. The system will chime to confirm that the vehicle is in programming mode. (Do not start the engine, just turn the key to the run position)
4) Key1 - Within 10 seconds, press any button on Key1. The system will chime once to confirm that Key1 has been programmed...
