My Transit didnt come with a jack. And the original jacks is too expensive. Any recommendations 8 ton, 10 ton, or 12 ton? I need to fit on the stock bracket and high enough to lift the tires of the ground when changing flat on emergencies. Thanks
You should be fine with a six ton jack, especially if you are concerned about weight and space. In addition to the jack, I suggest two to four short 2x8 treated lumber boards. I think mine are all cut in 12" length. In almost all cases, I use at least one board to set my jack on. Not sure about the front, but for the rear axle, it only takes a couple inches to get the wheels off the ground.My Transit didnt come with a jack. And the original jacks is too expensive. Any recommendations 8 ton, 10 ton, or 12 ton? I need to fit on the stock bracket and high enough to lift the tires of the ground when changing flat on emergencies. Thanks
