Several months of non-use, B2B charger non-responsive
5.2K views 20 replies 8 participants last post by  gvlive
#1 ·
I'm green in this arena. Took my van on its maiden 4800 mile voyage in March, got cut short due to the 'Rona. I tripped the breaker off the CCP to shut everything off and it sat for over a month. When I went back into the van and reconnected the breaker (80A Bussman), my Kisae Abso DMT1250 B2B charger is non-responsive. Brick. Dead.
Checked power from the CCP and getting 13.7~ readings. Took the van for a 4-5 mile drive to maybe charge the house battery, still nothing.
Kisae customer service is non-existent, almost like they're laughing at me.
In 3 weeks, I'm moving into the van FT. This is unnerving. Can anyone steer me straight? Thanks!
#5 ·
So I checked the leisure battery and it's at 2.3V, CCP battery at 14.3V
I don't understand how the leisure battery would stop the B2B from trying to charge it, especially since there's plenty of power coming from the van. Do I need to drive a lot to get it back up to speed? Even so, nothing is happening with the charger.
#8 ·
If you're measuring 2.3V at your house/leisure battery, it's way past dead. Most "smart" B2B chargers have protection circuitry/programming that won't try to charge unless your battery is above some set voltage. Even 10V would be considered pretty dead for a flooded lead acid (FLA) battery. Lower voltages can indicate a fault, like a shorted cell, so it wouldn't be safe to try to charge it under those circumstances.
This is assuming the voltage you're measuring is actually the combined/series cell voltage of FLA, AGM, or lithium, rather than some internal protection circuit that's been tripped on a lithium battery's BMS.
You'd get more meaningful responses if you say what type of leisure/house battery you have.
#11 ·
There are few, if any, batteries that enjoy sitting without a maintenance charge either periodically (lithium) or constantly (FLA, AGM, etc).
#14 ·
I've had some luck with smart battery chargers (e.g., Noco) reviving batteries that seemed dead. The one I have has a special mode to repair/recover. That said, I've had some batteries that were well and truly dead after discharge and neglect. When you get your house battery sorted, you need to have a shore charger that plugs in (or solar) to keep the battery topped off. A simple battery saver charger will do it, or use a hard-wired inverter/charger such as a Magnum.
#15 ·
The same thing happened to me recently when my van went to the shop for well over a week. I have a Kisae Abso DMT1230 hooked up to my house AMG battery. The Kisae would not turn on except for a momentary blue screen. My back up is a C-Tek smart charger within the system. I ran an extension cord to it, plugged it in and the house battery charged up over night. The Kisae is now functioning normal again, must that 8 VDC limit it has. I have since added a second cut off switch between the house battery and charger/components (the other cut off is between the van battery and the house battery). Now I can totally isolate the house battery if needed.
#16 ·
Just FYI, isolating a battery isn't enough to keep it from losing energy (voltage). It will self-discharge, thus needs a constant trickle charge. This is for lead acid.
Lithium also self-discharges but has different long term storage requirements, usually involving a lowered charge but check with maker for details.
Reactions: gvlive
#20 ·
Yes. But that is used to cut the power from the chassis to the house battery/charging system. You also need a switch on the positive lead from the house battery to the charger and the rest of the loads to keep anything from being powered and drawing power from the battery.
