Misaligned roof access hole and treaded hole
7.7K views 12 replies 10 participants last post by  SLOFO
#1 ·
Started the solar panel install and found that the roof access hole does not align correctly with the treaded hole. Anyone else have this problem? Any chance this is indicative of a larger problem (misaligned roof panels?)
#6 ·
I also needed to tap my threads to clean them up. I think it was largely paint in the holes and they were easy to do but I couldn't get bolts in otherwise.
agreed to both. We had to do both of these for a few holes.
Reactions: REDDOG
#7 ·
Very common problem for last couple years that I'm aware of. I have installed many ladder racks on the Transits over the last 3 years and I honestly do not remember once not having miss-aligned holes. This is just an expectation when installing anything on a Transit roof.
Walk up the ladder with the following tools every time I install a ladder rack.
Razor knife or scraper .... to remove the caps / stickers from atop the factory holes
Step bit ... to elongate the roof sheet metal to line up with the threaded hole
Sealant ... around and through every threaded hole. Avoid ANY water penetration NOW
Roof rails .... Tape measure ... tools .... and ladder rack
#13 ·
Some would Say Dicor self-leveling for that horizontal surface. I prefer Proflex and use it on my TT as well. I left all the caps on the roof that I wasn't going to use and covered over with some clear Proflex. For the 4 I did use I fortunately did not need to tap to be able to thread a bolt for the DIY Van V2 roof rail brackets. Since they came with a neoprene washer I didn't use any sealant there as per Hein's advice and there have been no leaks.
