Interior Dimensions
42K views 35 replies 19 participants last post by  orton
Does anyone have a good link to share that gives best details of interior dimensions for high/long and high/ext?
While I've found many search results, I haven't found anything yet that seems good enough to use for detailed layout.
TIA :)
The first drawing "Floor plywood and 80/20" on my web site may be useful for a 148"WB not extended:
http://www.ortontransit.info/drawings2.php
The layout was used for the 80/20 framework that sits on top of the added 1/2" plywood floor. The floor starts at forward face of the rear door frame and goes forward 130". There is also more information and pictures about the floor construction:
http://www.ortontransit.info/testfloor.php
Thank Orton.
Is there any info with the height and length on top of the wheel wells? Any info on interior height of the cargo area (for an MR van)?
Best to go to a local Ford dealer and spend some time measuring the size of the wheel wells. I spent several hours inside a couple of vans getting dimensions. If you measure you know exactly how it was measured.
I looked at my web site but did not find the dimensions but you might find other useful information.
