hi all, obviously a lot of factors here so i will try and be as descriptive as possible:
i am running a Bison 2000a gasoline heater which is tapped into my factory gas tank and is powered using a 100ah LiFePo battery system (will likely upgrade this in the future when i have a better idea of my power requirements) using blue sea components for pretty much all cable, fuses, and breakers. i have my house battery system grounded to the handbrake mount with dielectric grease in the connection. i live in alberta Canada and use my van mostly for skiing and mountain biking. battery is charged using renogy 40A charger which pushes a constant 35-39A until the battery is showing something like 4.3V using the bluetooth BMS monitor. battery pushes out what seems like constant amps when the heater and roof fan are drawing power. heater cranks closer to 10A when i used the shut down procedure. only loads the system is currently under are heater and roof fan.
the heater sat installed, but not connected to any power for about 1 year while i procrastinated. i recently got it running, and it was working great for about 2 months with moderate use. then, sort of randomly i noticed that the heater timer/control unit would reset every now and then when i got to the van the next morning, especially after a cold night. i don't think it is an issue with my battery though because it is Li which i thought can still discharge down to like -20C (and the van absolutely does not get that cold while i am sleeping in it). heater didn't seem to change though apart form maybe being not quite as hot. when i use the heater, i try and just use the max heat setting and the timer.
then, this past weekend i went skiing and parked for the night with my tank near half (the cut off for my heater's fuel pump). heater ran for 4 hours before kicking off and refusing to turn back on. i drove to town to try and warm the van up a bit, and when i parked and tried the heater again it fired up for the whole night.. i assumed i ran out of gas and found a hill that would prime the pump again.
however, the next night, i had lots of problems. heater turned on from 630pm-1130pm and then turned off. it was able to turn back on for about an hour before shutting off again. then i was able to get it going for another 2 hours before it shut off again at 130. started again and back off again at 3. then i was able to start it once more before it shut off at 5am and i wasn't able to get it going again; i spent like a day trying to start it up and it would just go thru the start up procedure and slowly blow thick white smoke (looked like someone vaping) before shutting off again
was the issue perhaps that it sat for too long before i actually used it? (i know they recommend you use them at least once per month)? to make matters worse, when i first tried starting it after it had sat, i probably had about 5-10 false starts and shutting it off quickly before getting to temperature because i didn't know what i was doing. maybe this gunked it up? further to that, i forgot to turn the timer off from time to time while the tank was close to empty so it would have tried to "dry start" a handful of times while i was away from the vehicle.
the other problem, and one more likely according to the shop that sold me the heater, is that i am not getting consistent voltage and that is causing my heater to run rich. i still need to buy a multimeter and learn how to use it, but figured i would start on here to maybe make my life easier when i pick one up today. anyone know what/where i would test? first culprit i think is the crimped connections may not be great from the heater to the fuse block (i didn't really do a proper "pull test" the first time i crimped the screw terminals on because i didn't want to buy a new connector out of laziness if it failed.. dumb i know). next point of error would be the ground i think; is this just a really bad spot to ground (saw Orton used it) or is it possible the dielectric grease between the ground contact is getting in the way from a decent ground? i fired up my roof fan last night and it does sound like the motor is running at intermittent speeds which would lead me to believe my system isn't grounded properly. i have a decent understanding of electronics, resistance, voltage, amps, i just don't know where to hold each terminal and what i should be testing for to actually determine what is broken (was going to try and measure resistance at the ground by holding one terminal at the handbrake steel near the ground and the other one on the ground connection at the fuse block but i have no idea if this is how i would actually do this).
long story short, how can i use a multimeter to test my connections and determine if my ground is bad, if my fuse block connections are bad, or is my battery just dyeing in the middle of the night? or is everything fine and it was just an issue with how i first started up and used the heater and i can just move on with my life lol?? so many options and not sure the best way to start trouble shooting it all... paralyses by analyses i guess.
thank you!!
thank you!!
