FYI - Special Tool Needed to Retract Brake Calipers
1 reading
53K views 10 replies 9 participants last post by  AIRAKULA
#1 ·
I couldn't find a recent thread on this with correct information, and I had a painful "learning the hard way" experience this weekend changing my brake pads.
I've done DIY brake pads and rotors for a long time, and have always retracted/rewinded brake calipers with a clamp, which has been easy to turn by hand.
On the Transit however, YOU WILL NEVER BE ABLE TO GET THE REAR BRAKE CALIPERS RETRACTED WITHOUT TWO SPECIAL BRAKE CALIPER TOOLS.
They do rent one at AutoZone, however it is RIGHT-HAND (RH) ONLY, which only works on the Drivers side.
You actually must have:
1. A Right-Hand (RH) tool to retract the Driver’s side caliper; AND
2. A Left-Hand (LH) tool to retract the Passenger’s side caliper.
I bought this tool for $22 from Amazon and it worked great (note the LH and RH on the box under the two tools):
For this particular tool, attachment #4 was what I used for the Transit brake calipers. To use the tool, put the large backing (#1 on this kit, stored b/t the tools) on it, then the proper sized attachment (#4) on the end, put into the caliper, screw the nut until the backing plate (#1) is tight against the caliper, and then turn the T-handle the correct direction to retract the caliper. I also used one of the pieces of the jack handle (stored in the outer panel of the front passenger seat in a blue pouch) for extra leverage to turn the T-handle... these calipers are a beast!
Working on a 2016 Ford Transit 350, but I am almost certain this applies to all years/models of Ford Transits.
Discussion starter · #2 ·
Oh and just one other quick lesson learned: the Brake Caliper Bolts are 15mm (front) and 13mm (rear); HOWEVER, the bottom 13mm in the rear needs a deep socket or wrench since it has a screw coming out of the nut. For this same bolt, you also need to hold a square nut in place while turning it or you will be turning all day!
