Full specs for OEM 70Ah AGM batteries?
17K views 9 replies 5 participants last post by  stevek
#1 ·
I'm having a surprisingly hard time finding full specs for the BXT-48H6-610 (that's the Motocraft number) batteries that came with my Transit.
Has anyone else found them?
Of course, now that I think of it, I haven't actually looked under the seat to see what's actually installed. But finding the specs for the battery specified in the manual would be a start.
#5 · (Edited)
The MSDS shows what the battery contains lead/lead acid/sulfuric acid - https://www.fcsdchemicalsandlubricants.com/main/msds/Lead Acid Battery SDS.pdf
Rather curiously it is missing from this chart. But based on it we can see this battery is considered 'Tested Tough Max' and is supposedly warranted until 100 month/unlimited mileage warranty w/ 36 month free replacement. This also shows the construction of the Tested Tough Max batteries.
http://machenry.com/documents/batteryspecs.pdf
Edit: You probably already knew the warranty based on here or similar -- http://www.fordparts.com/Commerce/P...jlS55RKEQ==&id=390174181&m=44&search=true&year=2015&make=Ford&model=Transit-250
#8 ·
The physical chemistry of lead/acid determines SOC for the battery. AGM will affect float/equalize times because the ion transport mechanism is different than a liquid flooded cell, but that is time only, not state of charge. The curves from any good battery manufacturer will do. The only real difference is how well they control the laboratory conditions while gathering test data. Temperature has a major effect on the voltage and that is the temperature at the point of the chemical reaction. Some labs monitor the case temp, others actually look at the lead plate temp.
The chart below is about as good as anything Ford can provide.
#10 ·
Forgot to mention that the available charge depends on temperature and how fast you discharge it so a 70AH battery (usually rated for 25 degrees C an 20 hour discharge rate) will be more like 50AH at freezing. Also if you pull more than 3.5A (70AH/20H) you will get less than 70AH of capacity.
