fastening plywood to the rear sides of cargo van
1 reading
10K views 8 replies 7 participants last post by  Paulmorabito
#1 ·
What is the best way to do this? I am wanting to mount plywood to both sides of the van to mount Milwaukee Packout shelving accessories. They will be holding a decent amount of wait. i could easily see 500-600 lbs per side.
I figured on the top side I could run metal or wooden "beams" across in 3 locations to keep the high sides of the plywood from falling in. I think that would provide a lot of strength and not depend on all of your strength coming strictly from just the fasteners.
I definitely dont just want to use some type of sheet metal screw. Maybe just nuts, bolts? I havent even taken the thin black plastic panels off of the insides to see what is there, but I have owned many vans and am sure it is similar stamped metal ribs.
Below is what im after. TIA!!
#2 ·
#5 ·
If it were me, I would build up a real frame to the floor for support at both the wall and the central aisle, not just hanging from the wall.
Rivnut strength itself is not the limitation, it is the steel wall of the van interior.
i gave up on rivnuts and similar - and switched to putting a stud through the wall and oversize washers. Some rivnuts into that thin sheet metal isn't going to hold anything in an collision.
