EcoFlow Power Kit GEN2 | Electrical System
Start-to-Finish Installation: faroutride.com/ecoflow-install
I never was a fan of portable all-in-one systems; there are just too many compromises.
But the Power Kit is a full-power, no-compromises permanent (it's not meant to be portable) system for RVs and Vans. As a bonus, I can also monitor my tanks' levels and temperature sensors (fridge, outside, etc.) with it (I installed a Simarine system in FarOutVan1 for that purpose).
If I can get an up-and-running electrical system in just a few hours (instead of several days, more like a week), and IF it works as intended down the road, then I can't see why I'd go through the hassle of making my own DIY system. Don't get me wrong, I feel very comfortable designing and making a DIY system, but I'm not looking for a new hobby. I just want to hit the road.
I'm aware of the single-failure point thing, but I personally know several happy users (full-timers), so I had to give it a try! Time will tell.
The Power Kit is incredibly versatile, but here's my setup:
Battery Bank: 10kWh (equivalent to 800Ah @ 12V)
Shore: 30A inlet (can be connected to a regular 15A outlet with an adapter).
Alternator: 100A charge current.
Solar: TBD.
DC Loads: 12V (100A total max). Can be set to 24V, but I prefer 12V.
48V Load: There is an additional 48V port for A/C, but I'm not using it.
AC Loads: 5kVa (4.000W continuous) inverter 120V.
Tanks Levels Monitoring: Fresh (x2), grey, toilet (tbd).
ORDERING
I ordered the Power Kit from Campervan-HQ. They're based in Portland (Oregon), I'd rather deal with them for after-sales service (they're responsive and it's easy to talk to a real human). With the "FAROUTRIDE10" discount code (10% off power kit), it's the best deal online for EcoFlow Power Kits.
PACKAGING
Unboxing is oddly satisfying and shapes the things to come; everything is neatly packaged and organized. No components were damaged.
HARDWARE
When I first saw the components, I could tell EcoFlow was founded by ex-DJI employees. Just like my Bambulab 3D printer. They share similarities. The hardware is very refined, and the material has a very high-end feel. All the included cables are protected in sheathing and conduit. An "Apple-like" experience. So far, it inspires confidence.
MOUNTING
You can tell their goal is to minimize user thinkering and labor. All the mounting hardware (brackets, screws, etc) is included, and 1:1 paper templates are also included to make things easier!
I designed and made my electrical cabinet. I'm still missing the "MOLLE" doors, which serve as organizers and passive ventilation. It's the same pattern as my Rear Door Molle Panels, so that the accessories are compatible:
The front panel is removable for easy access:
CONNECTIONS AND WIRING (TO BE CONTINUED)
Solar: TBD.
ORDERING
PACKAGING
HARDWARE
MOUNTING
