41 - 60 of 125 Posts
Discussion starter · #45 · (Edited)
Interested in these. How are they attached? Anything to drill?..
No drilling it uses all existing bolts. One of the bolts on the hinges is normal then the other 2 are tightened, this makes alignment easy because the door can be aligned independently from the brackets.
The following is my unpainted bracket, all others are powder coated black.
Middle bracket uses existing bolts and holes from the driver’s side door release.
@dinocarsfast, perhaps I ate far too many leaded paint chips as a kid, but I can't figure out how to DM you. I'm really interested in those brackets as well so I can weld up an aluminum frame for attaching various bits and bobs. Can you send me a message? Thank you!
Discussion starter · #49 ·
I just ordered another batch!
The estimated ship date from the manufacture is December 30th and I plan to be out of town that week so I the soonest I would be able to ship them out is January 3rd but more likely January 6th.
I apologize for the delays in ordering these to anybody that has wanted a set since the last batch, but I wanted to wait until most from the last batch were installed to verify if modifications were needed. Also I have been very busy with work(currently I'm in Dubai working on a USNS ship) and I just accepted a new job and I will need to move to phoenix in January. But if you are interested in preordering a set PM me, as I am unsure how soon it will be until I have them available on Etsy.
Discussion starter · #51 ·
Oooh, routing the bracket through the rubber seal is a good idea! Did you just cut a slight and then pass the bracket through?
Yeah, I spaced it so you make a cut as close to the door as possible along the seal and the bracket fits through
Interested. To new to dm, thanks
