Deleting Cargo Light Button from Overhead Console
1 reading
826 views 19 replies 13 participants last post by  Scalf77
I've got a 2024 cargo van that came with 2 cargo area lights around the C-pillar area. As far as I can tell there was no way to order the van without these. At any rate they are coming out as part of my conversion.
The problem is that the overhead reading light console now has this useless button that once controlled those 2 cargo area lights. I spent a lot of time on parts.ford.com trying to figure out a solution but couldn't come up with anything.
It's a good spot for custom switches so was hoping I could either replace the whole console dome with one that didn't have the cutout for the button panel or even better just source a blank panel that replaced the light button panel.
As far as I can tell all the cargo vans came with the light button there and all the passenger / crew vans came with rear climate controls there. It does seem like the dome part is also different depending on if the van came with the OEM overhead shelf (mine has the shelf).
Anyone else figured out a good solution for it?
#2 ·
He's some ideas.
Some people leave it (and the lights) in as a backup or secondary source of lighting.
Another option is to leave it in, but connect it to a relay that will activate your primary lights. Make it behave like a 3-way switch.
I will probably use this space for smart buttons, replacing the switch with a thin sheet of of plastic, or something I 3d print, or a thin sheet of plywood with a nice laminate in it inside the cutout. Even a thin sheet of flexible cutting board in the right color would work.
Lastly, I may just mount a proper sunglasses holder as it pisses me off to no-end that Ford must consider the cubby boxes suitable for sunglasses.
Love this! Exactly the sort of thing I aspire to, though so far an air compressor is the only thing I need a switch there for but maybe I can think of some other things. A valve on the grey tank is an interesting idea for sure.
Did you start with an off the shelf carling switch mount panel and cut out the existing dome to fit it?
If I put enough switches there to fill out the existing hole that would make it easiest. Sounds like otherwise my only option may be 3D printing something to take up the space around the smaller number of switches. I'm just really slow at CAD stuff so that's not my first choice. 🤣
#17 ·
Old Chub,
Did you run an entirely new power feed from your house system to the switch panel of simply tap the factory power feed? I would love to use that spot for a 5-switch panel with individual switches for exterior floods for each side of the van (one switch Aux.). Not sure if all-floods-on would be too much for the factory feed.
The wiring all runs back to my electrical cabinet and my house system. The roof rack lighting is all controlled by Shelly Plus 1 and Shelly Plus RGBW PM controllers. I can turn the rack lights on/off from 3 spots - drivers seat, slider, and rear doors (and the dashboard tablet).
#9 ·
like the other posters it seemed like space going to waste, though, i've not yet decided on what i'm going to put there. i'm also not sure if i'm going to use the factor lights but i figured i'd probably use the switch and maybe even the wiring it is attached to so i moved it down below where is also lots of unused space.
#11 ·
all the way at the rear of the top of van over the doors are two snap in spots and wire harnesses for the lights. A quick and useful place to stash them. The switch on the console can turn them on and off and will extinguish them over time if ignored
#18 · (Edited)
Would love to have that ability. I'm early in my build and getting ready to insulate/sound deaden above the headliner so will have access.
I've reviewed the following thread and it appears that by the end there was less enthusiasm for the Shelly.
(6) Let there be light! Shellies! | Ford Transit USA Forum
If one wants to control rack lights for example, with switches in multiple locations, should we follow the example posted in that thread using a Shelly RGBWPM, dual-port RJ45 and switches?
#20 ·
The sheer number of options in the same form factor from Carling makes these switches a great choice. You can generally choose your LED colors, switch type, indicators can be hard wired or independent. I generally just purchase the switch body, that saves a few bucks to put towards the etched rockers. The terminal housings are also a great addition for wiring up these switches.
