I know velit is the new heater on the block but every thread so far has seemed great. I haven't seen a thread that has been updated in a bit. As temps start to drop down again, does anyone have complaints with their unit before I purchase one?
Any updates on this I just installed my heater today and am getting the same error codetime for my own velit problems: i installed the heater over thanksgiving and was able to test it at the time successfully and didn't have my electrical system installed until this week. i started the heater up and got error code 7 (fuel pump error). i was able to prime the pump successfully but trying to run the heater again still had the same error.
i measured 8.6 V at the two brown wires going to the pump (seems oddly low but I'm not sure if this is a PWM pump or something?) and 0 ohm resistance there. can anyone confirm what their voltage is measuring at the pump?
I emailed velit and am waiting to hear back
Can you measure the resistance between both terminals of the pump? It should be about 5.5 ohms.Any updates on this I just installed my heater today and am getting the same error code
I unfortunately dont have a volt meter on hand I'll have to borrow a friends tomorrow. Do you take the measurement at pump harness?Can you measure the resistance between both terminals of the pump? It should be about 5.5 ohms.
My issue was a bad installation of the glow plug from Velit documented here https://www.fordtransitusaforum.com/posts/1341493/
I'm hoping my experience isn't typical for others but happy to help if I can
Remove the harness from the pump and measure on the pump itself (not the harness)I unfortunately dont have a volt meter on hand I'll have to borrow a friends tomorrow. Do you take the measurement at pump harness?
So the update has the lower set point? That's awesome. I sent mine in and had it done. I really like having a lower temp setting.They just came out with over the air updates to the ECU firmware so that's a big plus. I wanted to update mine to get the lower set point for winter time anti-freezing need, but wasn't relishing the $50 charge and wait involved in swapping out the ECU again. Now I don't have to do any of that apparently - but need to check first if my current firmware is OTA enabled or not. I'm guessing not since its ~4 months old from the bluetooth update.
