We've got a 2021 Transit AWD 3.5L eco-boost in the shop. Just noticed that it will not start. When the key is turned to position 2 all of the electronics are working. The interior lights work, radio works, electric seats work, etc. When key is turned to ignition there is nothing. No starter clicking, no cranks, just nothing. Batteries (dual AGM) are good.
I have a suspicion that the culprit has something to do with the DC-DC charger wiring/CCP connection. Last week we had a quick short to ground, when the positive lead coming off the CCP touched one of our ground wires, made a quick spark, and that was it. It tripped our 60amp Blue Sea Systems breaker. I am almost positive that we started and moved the vehicle after that happened, but cannot recall.
My investigations so far:
- Battery box - as stated, batteries are good. I checked all of the MEGA fuses inside the battery compartment. All of them good EXCEPT...
- the 175amp CCP2 terminal mega fuse was blown. This could be a big tell. What doesn't make sense is how that short to ground would have blown both 60amp breaker and the 175amp fuse. I would expect the 60amp breaker to go first, therefore protecting the rest of the circuit.
- So we replaced the 175amp mega fuse at CCP2. That did not fix the issue.
- Starter relays - inside dash fuse box there are 2 starter relays, load shed relay, and upfitter relay. Both starter relays were good as well as load shed relay.
- Immobilizer reset - assuming this Transit has the immobilizer feature, we did the 30-minute reset procedure to no avail.
- Fault warnings on dash - when key is turned to position 2, pretty much every fault warning flashes on the dash; this is not the specific dash lights, but the readout display. The CEL does not come on.
