Njvagabond.. Thank you for your detailed reply! I was able to dig up a comment from the CTEK folks stating that the SmartPass is not compatible with smart alternators. I think even with your method of disabling the SRC my CTEK equipment will always have issues. What would be the correct solution for something that is made for smart alternators? The "Victron Energy Orion 30amp DC-DC Isolated" charger? I imagine hooked in to CCP1?
Thank you again for your reply in trying to make my CTEKs work. I don't mind selling them to get what works best on my 21 transit.
I am not familiar with Victron. It has a very good reputation. IMO it is a premium product at a premium price, much of which is for features that are beyond my capabilities and needs. It I am sure there will be many that disagree. I'd suggest you make sure you understand what configuration of the unit might be required and how to do it.
Kisea, Sterling and Renogy all make B2B's that have ignition signal inputs to enable them to play well with the lower voltages of the smart charging algorithm. Each brand has it's pro's and cons.
I think with one battery you only have CCP1 T, so yes. Ford does not want you to connect directly to the battery. I think they say it messes with their BMS. Many people put a fuse or more likely a breaker at a lower amp rating than the Ford fuse outside of the seat base, since it's a pain to get to the Ford fuse. A breaker also gives you the ability to shut the charger off. (Also handy if you need to store LiFPO4 at recommended 80% SOC)
I am a big proponent of going to the primary source documentation. The manuals for all of these products are on line.
It's can also be a good idea to contact tech support for clarification on any questions. That also gives you an idea of what you could expect if you run into any issues.
