1 - 4 of 4 Posts
2015 Transit 250, Ecoboost
I seem to be having a few electrical problems right now, but I'm not sure if they're related. Currently, neither of my power windows will roll down. This has been a problem for about 6 months now and I think it may have only started with the driver's side, but nothing happens now when I try to roll down either window. I've tried the window controls on both sides (driver and passenger), while the key is in every position, and when the doors are open and closed... nothing. I checked the 30A window fuse today (F46 in the passenger fuse block) and it was good. I replaced it anyway, but still no luck. What should I try next?
A few other electrical things I've noticed: 1) About half of the time that I'm driving, I will get a door ajar warning when the door is closed. 2) The passenger side window control button is lit up at night when the van is off (I don't think it's supposed to be). 3) About 10 seconds after I turn off the engine, the dash needles all shake for a split second. I noticed each of these things around the same time as the window problem, but I don't know if they all started at the same time.
I'm wondering if I might have a bad ground that's causing all of my problems, but I have no idea how to begin checking for that...
The Door Ajar warning is most likely a separate issue, There are a number of threads here on how to fix this.
1 - 4 of 4 Posts
