I know that this has been kicked around a bit on other threads, especially after the Midea-U window A/C unit came out, but I've just completed a successful "science project" to convert the Midea-U 8000BTU window unit into a "mini-split" by separating the indoor and outdoor sections. I have no clearance in my garage for a rooftop unit, not $4000+ for a commercial unit... thus the necessity to attempt a split for less than $500.
Here is the video that gave me the inspiration where it looked like the two pieces could be separated by extending the electrical and refrigerant lines:
I talked with a couple HVAC professionals (I am not one) about the feasibility and they both said: "Yeah... it might work"
Here is a sequence of pictures of the process and end result...
Here is the unit "unboxed":
I removed the "control box" that is part of the outside and extended all electrical wires by 15ft, positioning all connectors at the end that will connect to the outside portion of the unit. The control box itself I decided to remove and join the indoor portion to prevent too much exposure to the adverse undercarriage environment (upper mid-west winters).
A piercing valve was placed on the suction side to evacuate the existing refrigerant (R32).
The outside unit will be positioned between the front and rear wheels on the driver's side. There was a thin support between the frame and side skirt that was removed to allow it to fit. Gutter screen was added to keep out larger debris.
Some brackets were fashioned to support it beneath the van. Super strut on outside and Plus-nuts inserted to the frame on the inside.
Charging the unit with new R410A refrigerant through valves added to the line set. The original refrigerant (R32) is used in Europe and East but is not readily available is the US as it is mildly flammable. R410A is a mix of 50% R32 and 50% R125 which negates the flammability. We hoped it was "close enough" to the OEM spec to work effectively.
Here's the indoor side of the unit mounted near the roof with the control box mounted beneath it. The control box has a heat sink (from the internal inverter?) and this position gives it good airflow to the bottom air inlet. This heat sink would normally get air from the condenser fan.
The line set is looped inside the van to allow enough slack to lower the external unit for service.
The electrical, refrigerant line set, and drain were all routed through a hole into the outside unit.
It hangs about an inch below the skirt but not as low as the passenger side step.
Air baffles were added to force the heated exhaust air downward and keep it from recirculating back into the unit.
What would I do different?
- maybe not relocate the control box. It may not have been necessary.
- maybe make a different box for the outside unit as the OEM case is a bit cumbersome to work with.
