When you get a system which mounts nicely and can integrate the rear view camera, please post your review.
I got the same system since I really wanted USB, at a minimum. I have many specific complaints, such as: 1) sync voice control is easily confused and goes down hill from there if it does not understand, 2) if you are shuffling through your USB stick (I have a 64 GB connected) and you switch shuffle OFF, it does not continue to play that album, but rather seems to continue to shuffle (or more specifically, does not continue with that album and artist in order; its version of Non-Shuffle is confused), 3) turn radio back on and it often forgets you were listening to the USB stick, 4) if you connect the stick it takes some time for it to register everything and says "unsupported device" or "unsupported encoding" if you ask it to play the USB before it is ready. Whatever happened to cars providing a simple DIN or double DIN mount. Everybody has to have their custom dash shapes to force you into their radios.
