was adding wiper fluid and I found this, and it seems like i don't have anything inside it.
was curious what it was.
I'm guessing it's just clean and very full. the van has only 3000 miles and it just was at the dealership for an oil change.If the fluid is clean and very full it can be hard to tell. Take the cap off and check. I highly doubt it’s actually empty, but if it is your brakes are probably not worth a lot.
Just tap the housing and see if the fluid level moves around.If the fluid is clean and very full it can be hard to tell. Take the cap off and check. I highly doubt it’s actually empty, but if it is your brakes are probably not worth a lot.
No. But as I mentioned in my long winded post there should be min-max marks on the side and you should be able to check the level without taking the cap off, in fact it should be more accurate that way.does engine need to be cold in order to open that cap ?
