1 - 2 of 2 Posts
I have a 2015 Transit that spews water on to the floor when the AC or defrost is on. The dealer said that he cleaned leaves and dirt out of the condensate base and re-routed the drain line, that did not fix the problem. Any one have a solution to my dilemma? Thanks in advance.
You probably took care of the leak by now but I just noticed your comment. My 2016 was delivered with the same problem. The dealer took it all apart and found a crack in the plastic somewhere and replaced the whole part which fixed the issue.
1 - 2 of 2 Posts
