Come up with idea to heat water using exhaust engine heat-
Heat goes to cold --->
Make C shaped copper plate to attach to exhaust pipe -
(Hose clamps)
To this plate spot weld heavy gauge copper Multi strand wire-
attach wires Many areas spread around C plate-
Larger gage = more heat transfer --
remove small amount of electrical insulation from wilt but
leave most -
then Add thermal Pipe insulation to wire-
run wire to water container and place in water-
Should warm or even make hot water -
to stop reverse heat lose / control temp remove wire from water
(Hose clamps)
leave most -
