1 - 4 of 4 Posts
I run an Architectural Millwork install company and use my transit as a rolling tool crib. I need a way to keep glue, caulk, and batteries from freezing.
Looking for a DC powered thermostatic control to run a light or heater coil in an insulated box or cooler.
What temp range are you looking at? Does the t'stat need to control DC or AC?
I've used these sort of inexpensive non adjustable t'stats in the past-
That particular one turns on at 35degF and off at 45degF...other ranges are available if you search a little. These use NO power on their own.
There is also this if you are planning on an AC heater and want plug and play-
1 - 4 of 4 Posts
