I can't seem to figure out how to quote like you, apologies...
It's a bit techy-ish... when you do the quote thing, you can grab the opener (where it has the QUOTE= statement in brackets) and paste it and the part with the /QUOTE wherever you like. If you do it right, it looks pretty organized. Use the Preview button to see if it's looking the way you want until you're comfortable with it.
"There's never too much energy storage. But your real issue will be restoring power to the storage. Solar is enough on some days; but there are many days it isn't. There are a number of ways to get power from the engine; that's where you'll need to focus when it's time."
I have seen the rechargers that will hook to your engine and I don't remember the right name if it's not inverter but you know what I mean. I will definitely have to get that. And I don't know how much room I'll have but aside from the space needed for the fan and AC do you think just blanket the top with panels ? Can you get to 1kw? Panels arent super expensive on Facebook marketplace. Luckily its going into winter so i have time to expand it.
Charging the house batteries from the alternator requires either a DC-DC charger unit (required because Lithium batteries use a different charge profile than the factory starter FLA/AGM batteries) or you can use an inverter IF you have an inverter/charger in your house system (we use this method - and, in fact, use both methods). This may sound like a lot of techy babble... but once you start looking into the components of a system, it'll make more sense.
Similar devices can work if you choose to go with more of an off-the-shelf system, such as the Ecoflow. That's the only one I'd recommend; but there are MANY off-the-shelf power-station things that meet some people's needs.
Can you get to 1kW of panels? Yes. But if you want to have a fan on the roof (very nice to have) or if you want a roof-top air-conditioner, then you lose space for the panels. There are people who have done a fan UNDER the panels... so that's possible.
I'm not as enamored of the solar panels as the be-all-end-all for charging because I use the van a LOT in winter. And I use it a LOT in winter storms. IOW, zero solar input for days. So... I have to be able to charge without them. Summer-time, yeah... most days, the panels are plenty; but there are plenty of days they are not.. so, back to alternator. I have my alternator charging maxed at ~1500W right now; but the new van is going to be 2kW and I will likely do the 2kW setup with the older van as well. With 1.5-2kW off the engine, the highly-unpredictable solar is more like a bonus than the core source of energy.
"There's room under the van to put about 45 gallons using the driver's (25) and passenger's (20) areas. After that, you have to get rid of the spare tire and/or hang small tanks all over the place. Then people will put as much as 40 gallon tanks over the wheel-wells. Just seems a helluva waste of space and weight. I sure don't want to be carrying 1000 pounds of water between fresh and gray!"
But I did agree with you that 50 gallons or whatever I can fit and another smaller tank is fine. I will just have to figure out the refill part. This will save me money and weight over my idea also.
I did cheap tanks for our old vans (Sprinter and 2020 Transit); but spent $300 per tank for a ready-to-go tank for each side of our newer Transit - 22 gallons, driver's side and 20 gallons, passenger side. Gray tank will likely be VERY small - I'll have to see how much space is left down there... but a small gray tank that's easy to drain... works fine for my usage.
I will post updates when i finish phases and get opinions. The insulation i guess is the first part, or should i work on the suspension first because I think you said that it's something you always do and others have said they've done like airbags to their suspension. Is that necessary before I start putting on the weight? I kind of worry about the cost of that if I can't do it myself but do you always do that before you even get started? I will make sure to research everything to do I'm just curious about timetables
The word, "insulation," is like a dog-whistle for a lengthy discussion on it... LOL.
I wouldn't sweat whether inside or suspension first. We did all the inside first on our 2020 and suspension stuff later. On the 2023, a lift and suspension and wheels and tires came first. It really doesn't matter much - other than not knowing exactly how heavy you'll be - which will mean some adjustment if not previously done.
Typical, "airbags," (like Airlift, which we have and a number of other folks here have), are NOT suspension and should not be used to lift or raise the van. They're good for leveling and for offsetting a temporarily heavy load or raising the rear-end up a bit for a short-term clearance issue. But they are not suspension. There are plenty of DIY alternatives to beef up the suspension when you're heavy - springs and over-riding springs, primarily. There are at least two pretty good DIY over-riding spring options. (I don't count "sumo springs" - the rubber bumper things - only their legit springs.)
As far as the inside goes, typically, it's sound-deadening first, then insulation, then floor, then (often) ceiling. But these things vary a lot with what your method and style will be. Our model is always modular - things can be disassembled and removed - so we do a bit of back-and-forth, removing a module (like galley or cabinets) to re-do something behind them or to re-finish them or whatever. Others are non-changeable / non-removable structure - very different, of course.
There are many, "build threads," here and they're probably the best thing to spend time perusing. I don't recommend any of the various YouTube things, generally - though there are some good ones, here and there - because the best you can get is a real-world blow-by-blow from a real person - not someone with enough views that it shows up in your feed. The build-threads here are that: real people, blow-by-blow of their thoughts, progress, set-backs... etc.
I personally like to work to a plan; but that plan is often a little loose and frequently shifts focus as I try something new or different. And I have a rule-of-thumb that I
will re-do everything three times. Thankfully, that doesn't apply to things I've already done a half-dozen times, like installing a heater or wiring up the electrical system - those I don't need to plan or think about too much, as I've done them many times.
But everything that is NEW I will often start, then let it sit for a while... then tear it apart and start over. Being committed to that premise saves a lot of, "well that sucked, but now it's done."
