My posts start on Page 19 with my description of the issue my van was having. It's safe to say there is some confusion in regards to what some people are experiencing and what I was. And to what extent. But I tried to lay out a timeline in my post of what was done with my rig and the results (or lack thereof). There was some assumption that the issue was with the drive shaft assembly which as you know has been recalled. Again this was an assumption and given that the sound is still evident to some extent, the drive shaft issue only accentuates the problem but is not likely the core of the issue.
In the effort to resolve the "Droning" problem we initially had the guibo replaced under the recall temporary fix. Mind you this was just over 700 miles, not the 30,00 recommended. It was as much a troubleshooting measure as a recall issue. Eventually, the dealer got a Ford engineer involved. The engineer had the, take apart the back end and inspect the gears and bearings. The pinion bearings had accessive and uneven wear and were replaced. The drone issue remained afterward which tells me the pinion bearing wear was a byproduct of another issue yet discovered. My feeling is the driveshaft issue caused the wear on the pinion bearings. Which I wonder if they bother to inspect when they perform the final fix. If not, you may get the final fix only to have pinion issues down the road.
Eventually, they managed to get the "permanent fix" components for the drive shaft. They have been installed and the drone is considerably better. Probably 80-90 percent. Quiet enough that if it was that way originally, I probably wouldn't have been concerned. AT this point they have no idea what causes the drone. And I have run out of time and must have the vehicle for work. They feel it is not a safety concern and really the vehicle feels great.
In regard to expediting any efforts on the dealer's part, it will depend vastly on your dealer. Our dealer was a complete catastrophe to deal with. Timing is everything and this dealer was falling apart at the time we purchased the van. The salesman who sold it to us left the company. The Manager was demoted. A general manager took over that position and was putting out fires left and right. He was completely unaware of our situation until I tracked him down and spent an 1.5hr explaining the timeline. The communication between the people taking in the work and those doing it was completely useless. Nothing I would explain was passed on to the techs. So a lot of time was spent chasing down issues that weren't there and not chasing down the ones that were. Literally, months were wasted and nothing really got on track until my talk with the GM.
If you have a solid dealer, maybe you will have better luck.
