21 - 29 of 29 Posts
The guibo is probably REDUCING a lot of vibration, as is it's purpose in life. It makes up for some imbalance in the driveshaft. With the U-Joint, they have to balance and fine tune everything to avoid vibration.
A little research may have been in order, This has been a complaint since the first model year Transit.
This was my first brand new vehicle purchase, I said I can learn to live with it. The Transit was better then anything else out there at that time.
Ford should have mandated transmission fluid change intervals at 50,000 miles for anyone doing regular towing. Their "lifetime" fluid claim is crap. There are enough failed/failing torque converters scattered across the U.S. to prove it. My torque converter is failing at almost 100,000 miles. To be fair, we towed a 4,000lb travel trailer around the southwest for 2+ years. We pulled that same trailer from Vegas to Virginia during our move. I recently towed 4,000lbs of trailer and tractor from Pennsylvania to Virginia. Had I not bought into Ford's lifetime fluid BS, I would have had my fluid changed at least once a year when I was heavy towing. It's cheap insurance at $250--what the dealer charges for a fluid exchange. I'm adding a transmission cooler when I get my torque converter replaced either this fall or next year. After a transmission fluid exchange, the torque converter "shudder" is dramatically (75%) better but I know the TC will fail eventually if left alone.
Hindsight being what it is, I should have done my due diligence. I assumed the "shudder" was just the driveline (guibo) or old tires until I put on Michelins and the shudder was the same, almost ever-present.
So I have a 2015 that I spent over $2000 having the reared rebuilt. I did the driveshaft recall twice. It vibrates at about 40mph and if I take it out of gear and coast in neutral it still vibrates. Its around the 40mph that it starts. The van just turned 70k. I am beside myself with it
Did they test if the shaft was balanced? What else did they troubleshoot?
A follow up to my previous responses: I told the dealer that I did not want to purchase a rebuilt transmission or a new torque converter. I did ask them to perform a transmission fluid exchange, which they balked at. They tried to talk me out of it, told me it might help a little but wouldn’t cure anything.
When I first picked up our van it was maybe 50% better but still had symptoms of a failing torque converter. I was patient and with each drive the vibration got better. More than 500 miles later and all symptoms of the torque vibration are gone — I mean 100%, driving like when it was new. I’m sure at some point I may need to replace the torque converter. If I do, I’ll report back here.
If you have the torque converter shudder, get a fluid exchange done, either by a Ford dealer or a transmission shop. You might end up saving a few thousand dollars.
21 - 29 of 29 Posts
