Alright, for all of you who have been losing sleep in great anticipation of the next installment of this thread....... oh who am I kidding? Just read below if you give a sh*t and pass on by quietly if you don't.
These instructions appear long, but only to be thorough. This is very, very simple.
This applies to Windows 10 Home, up to date as of 2019-03-04
1. Insert CD and run "Setup.exe". Follow prompts and install normally.
2. Run program, make sure everything works. This may also contribute to creating files we'll need later so don't skip it.
3. Copy contents of the CD into a newly created empty folder on your hard drive. I chose "C:\TSO\CD_CONTENTS" to keep related things together.
4. Install the required stone age software from "C:\TSO\CD_CONTENTS\tools" :
Code:
SVG Viewer --> C:\TSO\CD_CONTENTS\tools\adobe\win2k\SVGView.exe
Adobe Acrobat 6 --> C:\TSO\CD_CONTENTS\tools\adobe\win2k\ar600enu.exe (there are some references to 5.0 but mine included 6.0 and worked fine)
Visual C Runtime Library --> C:\TSO\CD_CONTENTS\tools\vc\VCREDIST.EXE (may not be needed but likely won't hurt either)
5. Remove the CD and put it somewhere safe but pray to whatever deity you believe in that you'll never need it again because Helm Inc finally made it to the age of online software delivery and/or solid state storage media.
6. Open the file "C:\TSO\tsobrowser.ini" in a text editor (if you don't know the difference between a word processor and text editor, stop now before you hurt yourself!).
7. Change the following line:
Code:
FROM --> "18SJX=1~3~D:~stock\home.htm~2018 Transit~October 2017"
TO ----> "18SJX=1~1~C:\TSO\CD_CONTENTS~stock\home.htm~Helm Inc Sucks Big Time~It's 2019, not 1920!"
(Where you may need to replace "C:\TSO\CD_CONTENTS" with your folder of choice, and you can pick whatever customized title/message you want if you don't agree that my suggestion rocks. If you can't figure out whether or not to include the quotation marks, stop before you hurt yourself or someone else!)
8. Save and close the modified file and you're done. Enjoy the electronic manual that Helm Inc charged you way too much money for at greater speed and without the hassle of requiring the CD every time you use it.
*** BONUS ASSIGNMENT ***
9. If you're a real keener and have more time to waste than I do, figure out what all happens on installation in the registry or elsewhere. Make a simple script that updates the registry with these things, and now you can move the software to any computer you want. Share it with your friends at work, share it online, share it with the homeless person down the street. Helm Inc has made enough money from this horrible antiquity.
