1 - 4 of 4 Posts
Hi,
I’m wondering if anyone else has had an issue with their battery monitor showing that the battery is charging when it is actually being discharged, or vice versa. When I hook up my AC shore power charger, the monitor says the leisure battery is being discharged. When I turn on the lights and discharge the battery, it reads as it is charging. This is the system I have installed. Any ideas would be appreciated!
139559
139558
The shunt (or at least the voltage measurement connections) is directional/polarized. If you connect it backwards it would give the symptom you describe.
Your diagram looks right at first glance. Just make doubly sure the shunt is on the low (-) side or things may smoke.
Reactions: gemanimal
Discussion Starter #3
As far as I can tell, I thought I had hooked it up correctly... Does this look right?
139591
1 - 4 of 4 Posts
