bedslide 1500, 4' x 6'thanks. What pull out did you use looks like it fits perfect
How did you install the sheet vinyl flooring? Assuming you had the carpet beforeMy initial build was a minimal bed that could be removed to replace seats back to stock. The longer I had the van, the more I realized:
I stumbled upon Vandoit and really liked their builds so modeled my own after theirs. Their LIV model uses a manual hydraulic lift to raise and lower the bed, which I really liked. No need to run power, and additional clearance for bikes when needed. I was also lucky enough to find a bedslide on craigslist that fit perfectly. Their DO model allows for beds to fold out of the way and be reconfigured. I eventually arrived on a combination of the two. I started by modeling the side cabinets and bed base. Using 15 series extrusion, I also mocked it up using 2x2s to verify my CAD. The goal was to order cut to length and tapped so it could be assembled as a kit.
- I did not convert it often, as my mattress was heavy and hard to store
- The space underneath the bed was too small and hard to use
- I became more comfortable veering from the idea of returning to stock
View attachment 145507 View attachment 145508
Initially I had planned to run lateral extrusion and U-bolt to the original seat mounts to create mounting points for the bedslide, but changed to using ¾” ply as a cheaper temporary setup. I removed some material and added some kaizen foam in non-structural areas to hide tools or other items.
I had a solid bed frame designed but worked on the idea to split it in the middle so each half could fold out of the way. I added an overhead rail with some supports to hold movable/removable shelves, a TV, lights, as well as the bed halves separately.
I replaced my heavy memory foam mattress with two tri-fold cot sized mattresses. I can configure a near-queen E-W, or set-up just half to be a cot size, although I will need to add an extension. There were some dimensions I changed on the fly and will need to adjust to have my halves fold down straighter, they can also fold up when the hydraulics are in the lower position. The intention was to allow the option for the kids to sleep below the bed on the bedslide when needed. When in Queen E-W position the two halves are supported by braces which get stored under the bedslide when not in use. The hydraulic has a 16" stroke.
For electrical I used a Goal Zero Yeti 1000 and Trigger six shooter controller.
I reached a usable state and progress slowed. Still to do is finish out the side cabinets for usable storage, finish wiring, probably add some sort of heater, and countless other things.
Also added:
Cheers!
- Upgraded jumper seat to quick release
- Replaced carpet with sheet vinyl
- Maxxair
- Thinsulate insulation in ceiling
- Custom Extrusion roof rack
- OVS 270 degree Awning
- Flatline Van Side Ladder
- Passenger side swivel
- B-Pillar Lagun Table
I took out all the seats, heater vents, and then a few trim pieces and just pulled the carpet off of the subfloor. Then used the old carpet as a template and cut the sheet vinyl. The floor was mostly still tacky but added some 3M90 spray and tried to smooth it on.How did you install the sheet vinyl flooring? Assuming you had the carpet before
Thanks! I installed a 1/4-20 rivnut into the roof rib where the gray plastic tree holds the headliner. This hole is in the same location on all the ribs. Then I measured and drilled holes on the extrusion. I've thought about offering some plans for the complete build to make it easier for others.This is a great build. Nice job! I have been planning on modeling my van off the VanDoit vans also. Do you have any pictures of how you secured the 80/20 to the ceiling? I am about to buy a Dyna lift kit. Do you recall what hose lengths you ordered? Looks like the kit with 20" throw and mounting hardware will be around a thousand bucks!
Nice! Good luck with your build.Wow! This is just what I’m doing. I got a cargo slide from Craigslist and started my side cabinets. I have the dually so I had to raise the slide which gives me more room under but makes the slide higher.
After spending a weekend in the van with the kids started to figure out bunk beds. Looking for ceiling tracks got me to Vandoit and then to here.
I’ll skip the bed lift (at least for now) and work a “Camping Cube” out of lighter (& cheaper) 2020. The Cube will drop on the cargo slide and be my camp kitchen.
what size t-slot did you use for your upper cabinet build?
I used some 2" square steel tubing, I believe, and cut it into L brackets because I had it on hand. I'll probably make some aluminum L brackets at some point in the future.@Knarfly great looking build!
What did you for what appears to be black brackets to connect the bed frame to the rear door frame?
Thanks.
I am also doing a build in a passenger wagon and have concerns over airbag clearance. The Body Builders Layout Book indicates "DO NOT INSTALL ADDITIONAL COMPONENTS IN THE SHADED AREAS, NOR ALTER OR MODIFY THESE AREAS"I hope I am wrong but in the transit airbag video the airbags come down from the windows but the whole headliner is allowed to move out to make that
No regular height gallery goes higher than the factory seat height. So I dont see an issue. The airbag fold down toward the window when it goes off.I am doing the same -below cupholders as I need to keep passenger capability.
Other folks see it differently or have additional info. There are two videos- the one with the headliner installed shows how much it comes out to let airbag go, That was my evidence for my choice.
I also don't want insurance to void a claim, if that ever were to happen.
I even added umbrella insurance after a recent experience.
I'm not sure how Vandoit secures theirs. I used some rivnuts that I installed behind the trim just below the window sill in the factory trim, and the D-Ring threaded hole above the wheel well. These were installed for my first bed iteration.Can you take some photos that show how the bed frame is connected to the van body? I have been trying to figure that out on the vandoit photos, looks like all the lower trim is still installed and the frame sits in of the trim but I can’t see where and how it gets secured to the van.
Knarfly, so you replaced the long plastic tree/plug with a rivnut. Then what? Did you drill holes through the 8020 for bolts to the rivnut? Or is there a better mounting for the 8020?I installed rivnuts into the ribs where the gray plastic headliner plug typically goes.
Sorry, I scrolled further...let me rephrase my question. How does the new connection work? How long a bolt did you need? Is a spacer necessary between the ceiling rib and the headliner? How precise do the holes need to be in the 8020? Is a washer used behind the bolt head? Thanks for your patience!Thanks! I installed a 1/4-20 rivnut into the roof rib where the gray plastic tree holds the headliner. This hole is in the same location on all the ribs. Then I measured and drilled holes on the extrusion. I've thought about offering some plans for the complete build to make it easier for others.
For my needs I decided the 16" was sufficient, I was able to get mine around $500. Tube length was standard 2x96" & 2x60" which was more than enough. I wouldn't buy their mounting brackets either as they're ridiculously expensive, although it is an odd mounting spacing you can easily make your own brackets with some aluminum plate or extra 8020 brackets, or try and drill straight through the extrusion. Someone else on here found an electric version with 25" stroke for around $900 which would be a good option as well.
There are two ways to do it. I drilled a 1/4" thru hole, or "access hole". I then slid the head of the bolt under the ceiling side of the extrusion, slid it to align with the roof hole, and then use your hex screw driver from the underside to tighten through the access hole. This allows the bottom facing T-Track to not have any stop points, but is harder to get the track up...like a real pain by yourself. I used a 2-1/2" long bolt as it needs to reach the rib before it compresses the headliner foam.Sorry, I scrolled further...let me rephrase my question. How does the new connection work? How long a bolt did you need? Is a spacer necessary between the ceiling rib and the headliner? How precise do the holes need to be in the 8020? Is a washer used behind the bolt head? Thanks for your patience!
Sent from my SM-N976V using Tapatalk
