I'm doing a camper conversion on a Ford Transit 2023 extended....
I already have a grey tank on driver side for the shower.... I would like to mount another tank for the sink.
I saw one tank 10 gallons but the seller doesn't know if it fits with the factory running board.
I saw another one with 16 gallons, seller is saying doesn't fit with factory running board but I read that somebody was able to fit.
Can somebody share there experience with mounting grey tank under passenger side with factory running board ?
You can get Pelland to make you a tank to your specs, cheaper than the NW conversions tank, but I'm not sure if it can be a shape other than a rectangle, if that's important to you.
Buy Class A Customs | T-0500 | One (1) 5 Gallon RV Fresh and Gray Water Holding Tank RV Concession: Freshwater Tanks & Inlets - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
I tried this tank and it was close to fitting but it didn't fit.
Buy Class A Customs | T-0700 | One (1) 7 Gallon RV Fresh and Gray Water Holding Tank RV Concession: Freshwater Tanks & Inlets - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
I installed this motorized ball valve on the gray water tank. I have a switch on the B-pillar near the drivers seat to make it easy to dump the water. The valve works very well.
Motorized Ball Valve- 3/4" Brass Ball Valve with Standard Port, 9-24V AC/DC and 2 Wire Auto Return Setup by U.S. Solid: Amazon.com: Industrial & Scientific
I am looking into a wheel well tank and I noticed that the 32-gallon go-to tank leaves a "generous" amount of room around the transit's wheel well. I want something a little narrower, so for kicks, I did a quick sketch to see what an optimized design would look like. NW Conversions 32 Gallon...
