1 - 2 of 31 Posts
2021 R2C Ecoboost Buejeans
That's exactly what I was talking about. Here's a pump I've seen people use:
/[/URL]
And a faucet:
/[/URL]
Just submerge the pump in a jerrycan and you have a water system.
That is the system I’ve used. Simple, easy to maintain, fill and simple to replace/repair. After a couple boats, decided that I did not want a permanent tank worrying about “funky water”, just replace the jerry can if necessary.
Wood Rectangle Floor Flooring Hardwood
Simplicity is a selling point for sure. I'm pretty well decided on a jerry can system, just not sure if the tradeoffs of not having a pressurized system are right for me.
I'm looking for a set of Möbius tires, twice the surface area for twice the life.
The jerry can idea is simple. Hardest part was finding the right style container with an opening that the pump easily fit through, which also accommodates easier refilling.
Gas Shelving Shelf Machine Metal
Gas Machine Motor vehicle Nut Metal
The plastic lid is easily drilled and using synthetic cork to create gaskets for the water line and pump wiring. This can also has a breather hole to allow venting. Available on Amazon
1 - 2 of 31 Posts
