1 - 3 of 3 Posts
I recently installed a hitch on my 2015 Transit 350 HD cutaway with a Reading utility box on the back. The truck came from the factory with the "tow package". I got a harness from Ford
(part# CK4T-13B576-KB) and wired it to the combo 4 pin- 7 blade trailer plug. The LED step I installed & plugged into the 4 pin on the receiver hitch works fine until I activate either turn signal. It will then intermittently blink very fast. Any idea's on how to fix this problem? Maybe a different flasher relay? If so can you identify the exact location on my vehicle?
led are funny, if wired wrong they can cause all kinds of problems with the vehicle lights, i would say check and make sure the hot and ground are wired right on you new light, other then that i do not have a clue?
1 - 3 of 3 Posts
