1 - 17 of 17 Posts
Hello, my name is Joe, I have a 2015 transit 250 with the factory tow package. I recently ordered a tekonsha brake controller that came with a plug to go directly to factory wiring, however I can't seem to locate the factory harness to plug into. Any help worth this would be greatly appreciated!
The reason is that, as far as I know, the tow package always includes the brake controler.
But, if his doesnt, of course the added controler would work.
No- it does not. In fact the tow package alone never includes the factory brake controller.
The brake controller is a separate line item option- somewhere over $200.
To answer the OP's question- mine has the tow package which includes the trailer wiring option but it did not have the pigtail under the dash either.
It was a major PITA to work around that and finish the wiring.
I'm sorry, I didn't know that. Without a hookup under the dash, it would be a pain.
I have a XLT wagon with the tow package and the brake controller which is a separate item as mentioned. I would be surprised if the trailer tow package did not include the pigtail. My previous E150 did, it had three wires one fused feed wire (black) one to go to the trailer plug and one from the brake pedal switch which activates the after market controller. There is a removable panel under the steering column (just pull it off) it may be behind there. There is a fuse box back there, compare the fuses to your owners manual to see if the brake fuses are there.
Discussion Starter · #9 ·
Thanks
Thank you for the responses, I DO have the tow package, i DO NOT have factory brake controller. This is really starting to piss me off, tekonsha makes a pigtail for this application which would leave me to believe that there is a factory pigtail somewhere in there. i have looked diligently under the dash and there is nothing even close to resembling the hook up that i need. i will continue to research this and let everyone know what i find.
thanks again!
thanks again!
Yeah I too ordered the Tekonsha pigtail before looking, and like you discovered the Ford portion isn't there.
To be honest the wire they ran for brake and especially the battery charge is also too small.
Would have been easier and quicker to just do it myself with all the time I spent figuring out what they had.
I saw a video on You Tube of a guy that had an F150 with a trailer tow package but no brake controller. He bought a Ford controller from a dealer pulled out the coin holder and the cable and plug were there. I'm wondering if you pull out the coin holder on your Transit will the wires you are looking for be there. Check out the video.
Discussion Starter · #13 ·
Solution
all though not a good one i have found a solution to this issue. took the truck to my mechanic to see if he would have better luck either finding the factory pigtail or just hard wiring the unit. after man calls and hours on the phone with ford we were told that there is no factory pigtail in my van because this one has 'the partial tow package" (straight from ford) thats funny because i paid for the tow package and was never told anything about a "partial package" otherwise would have paid for the "full" package. needless to say my mechanic had to hard wire the unit which also took a few phone calls to ford because the wires from the 7 blade plug on the back of the truck were run into the engine compartment and thats it. they were dead ended and not connected to anything in the engine compartment and never enter the cabin. Job is done now and working great, thank god i have a good honest mechanic who only charged me 1 hour labor event though he was at it for half a day. Hopefully these findings can help others that may run into this ford fail!
This what I pulled out of the new BEMM ( new thread today) page 24. Hope it helps.
1.12 Towing
If planning to retrofit a Tow Hitch to extended
wheel base vans and wagons, ensure Trailer Wiring
Prep Pack (order code 59B) is ordered on the
vehicle.
NOTE: Wiring Prep Pack (59B) only guarntees
support for trailer lighting.
NOTE: If trailer brake functionality is required order
Trailer Brake Controller (67D). Heavy Duty Trailer
Tow (53B) provides connector in instrument panel
for add on trailer brake controller.
NOTE: See Trailer Brake Controller (67D) for
requirements necessary for addition of trailer
lighting capability on capable vehicles.
NOTE: There is no wiring provisions for Trailer Tow
operations provided on the base vehicle.
For additional details regarding coponents
necessary for the addition of trailer lighting
Refer to: 4.1 Wiring Installation and Routing Guides
(page 52).
Electrics for Tow Bar section.
NOTE: Tow Haul Mode is only available when
ordering Trailer Tow packages 59B or 53B
For availability please contact your local Ford
Dealer.
Date of
BTDT.
See this post- http://www.fordtransitusaforum.com/towing/15130-trailer-sway-control.html#post189666
Went through the same thing about it not being a complete tow package:(
Someone at Ford needs to be drawn and quartered...
Reactions: larry8061
And the dealers ordering lot vans should always include the tow package with brake controller - because even if you have no plans to tow, that could change and so many other people tow that that minor inexpensive option will affect resale value.
Good honest mechanic
I also have a good honest mechanic, and have found he likes to be remembered at Christmas. A gift certificate for him and his family to go out to eat somewhere has always made him glad to see me come through the door again instead of saying #&@! not this guy again.
1 - 17 of 17 Posts
