OK, brain fart. Now I get it.
No. According to the factory specs it is specifically rated 2000 watts continuous.your inverter is probably rated for 2000 watts peak power, at best it probably puts out 1000 watts continuous. my inverter puts out 2000 watts continuous and costs more then 5 times as much as that one. (of course my inverter has a battery charger but i do not see the charger costing more then 1/3 to 1/2 of my total price.)
Home depot has a two circuit breaker box that is small and works well. I run two of them. One for my shore power and one for my inverter. Your inverter has a floating ground so don't tie the neutral to the ground.I've got fuse blocks up the yin yang for the 12 volt system but realized I need one for the output side of my inverter. Originally I had planned to have only one outlet wired to the inverter but decided I should have a couple more.
Any recommendations for a suitable fuse block with provision for negative terminals as well? I'm looking for something simple, no more than three of four terminal connections necessary.
My inverter is a MorningStar 300W, wondering if a DC fuse block wouldn't be sufficient.
Agree, I just reread the original post, I thought I saw 3000 watt but now see it was a 300 watt.I think you're over thinking it.If you just have a couple of AC uses, just get a good breakered extension cord.
You have covered the problem. 150 watts is not enough and you need the roof space to install the correct size.After a month with a single 150watt solar panel, I can categorically say that a single panel is not worth the effort, for my uses.
where most of the roof area is used by a platform rack -- solar is meh...
