1 - 1 of 1 Posts
· Banned
:)My full Wagon order finally appeared on the Ford ETIS web site today. Although the build date shows as 17 Nov, the window sticker shows production began on 6 Nov.
Primary Features Build Date: 17.11.2014 Vehicle Line: Transit V363 Body Style: Bus (M2) Version: 390M Engine: 3.5L V6 GTDI Transmission: 6 Speed Automatic Trans (6R80) Drive: LHD RWD Axle Ratio: 3.31 Emission: 50 State Emission Requirements Air Conditioning: Manual Air Conditioning Paint: NX Green Gem Number 2 (because my wife likes green)
Minor Features
  • Pewter
  • With Medium Roof
  • Less Roof Line Conversion
  • Less Rear Mudflaps
  • Less Accessory USB Unit
  • Less Front Mudflaps
  • With Kerbside Side Load Doors
  • Less Diesel Particulate Filter
  • Less Hill Launch Assist
  • Less Bulkhead
  • Less RH Side Loading Door
  • With Front Passenger Door
  • With Hinged Rear Loading Doors
  • Side Loading Dr Opening-Restricted
  • Less Folding Step - Side Door Load
  • Less Second Unit Body
  • Less Mesh Headboard 2nd Unit
  • Less Tailboard Support Straps
  • Less Auxiliary I/P Console
  • Less Load Box Bedliner
  • 129"/3335MM Wheelbase
  • With Standard GVM Rating
  • XLT
  • (-) Version Packages
  • Kansas City Plant Build
  • Less Special Equipment Package
  • Complete Vehicle
  • 8550 LB. GVW
  • Trend Sales Badge
  • Less Special Order Paint
  • Less Trim Pack
  • Exterior Appearance - Level 1
  • Less Functional Upgrade Pack
  • Less Visibility Package
  • Exterior Paint - Solid
  • Less VP Application Label
  • Owner Hand Book Pack
  • Less Fire Extinguisher Fixings
  • With Tool Kit
  • Less Tyre Repair Service Kit
  • Power Front Windows One Touch Up/Do
  • With Privacy Glass
  • With Front Side Standard Glass
  • With RH 2nd Row Fixed Window
  • With LH 2nd Row Fixed Window
  • With RH 3rd Row Fixed Window
  • With LH 3rd Row Fixed Window
  • Less 4th Row RH Side Window
  • Less 4th Row LH Side Window
  • With Fixed Rear Window
  • Less Heated Windscreen
  • With Heated Rear Window
  • Less Console Ashtray
  • I/P Rubbermat
  • With Glove Box Lid
  • Standard Ovrhed Console & With Rail
  • With Full Floor Console
  • Less Rear Cupholders
  • Less Header Mounted Package Tray
  • Side/Rear Door Trim Panel-Level 2
  • Less Inter Cladding Surfaces
  • Frt Floor Mats Throw In-All Weather
  • Less Rear Floor Mats
  • With Carpet Floor Covering
  • With Full Headlining - Moulded
  • Sun Vis-Drv Mirror Insert/Illum
  • Sunvis-Pass Mirror Insert/Illum
  • Rear Coat Hook
  • With A Pillar Assist Handle
  • With B Pillar Assist Handle
  • Less Rr Interior Overhead Stowage
  • Less Load Compartment Loops
  • Less Load Floor Covering
  • Less Load Area Protection Kit
  • Less Cargo Stowage Rack/Rail
  • Roof Storage-Driver Sunglasses
  • Running Boards - Door Length
  • Chrome-Plated
  • Wide Bodyside Moulding-Grey
  • Less Side Auxiliary Step
  • With Dipping Rear View Mirror
  • Large Head/Long Arm Mirror
  • Dual Power Htd Signal Mirrors
  • Less Auto Dipping Mirror System
  • Single Passenger Seat
  • Seat Pack 7
  • With Drivers Seat Armrest
  • With Passenger Seat Armrest
  • With Front 2 Way Headrest
  • With 2 Way Adjustable Rear Headrest
  • With Rear Seat Centre Armrest
  • With Manual Rear Seat Recliner
  • Less Driver Seat Lumbar Support
  • Less Passenger Seat Lumbar Support
  • Less 6th Row Seating
  • Less Temp Control Driver Seat
  • Less Temp Control Passengers Seat
  • St Belt Minder-Drvr/EU Tel&Snd
  • Second Row Dual Seat
  • With 3rd Row Single/Double Seat
  • With 4th Row Bench Seat (3 Pass.)
  • Less Fifth Row Seating
  • With 10 Seat Configuration
  • With Driver 10 Way Pwr Seat Adjust
  • With Pass 10 Way Power Seat Adjust
  • With Trailer Towing Attachments
  • With Trailer Sway Control (TSC)
  • Exterior Door Handle - Black
  • Lift/Bootlid Handle Exterior-Black
  • Ignition Key Combination Pack 1
  • With Leather Gear Shift Knob
  • Bus (M2)
  • Less Fleet Key
  • Less Keyed Alike Options
  • Less Zonal Opposite Door Relocking
  • Configurable Unlocking - Conf 2
  • With Central Locking System
  • Dr Entry Remote-Single Channel
  • Keyless Entry - Illuminated Key Pad
  • Less Rear Window Wiper/Washer
  • With Automatic Windscreen Wiper
  • Less Headlamp Washer/Wiper
  • Less Washer Tank Level Warning Lamp
  • Less Rear Sunroof
  • Front Bumper - Partial Body Colour
  • With Grey Plastic Rear Bumper
  • Less Rear Bumper Under Run
  • Less Front License Plate Bracket
  • With Front Bumper Under Run (N2)
  • Restrain Device Pack 1
  • Air Curtain LH Level 2
  • Air Curtain RH Level 2
  • With Inertia Front Seat Belt
  • With Standard Rear Seat Belts
  • With Driver Air Bag
  • With Passenger Air Bag
  • Less Passenger Air Bag Deactivation
  • With Isofix Hard Point Attachment
  • Style 1 Tether Anchorage Restraint
  • Seat Belt Pretensioners Drv/Pass
  • Drv/Pass Seat Mounted Side Airbags
  • Tyre Carrier Drop-Dr Open
  • Less Side Underrun Rails
  • With Steel Spare Wheel
  • With 4 Wheel Tyre Pressure Sensors
  • Less Spare Tyre Lock
  • With Single Rear Wheels
  • 6.5 x 16" Styled Steel Wheels
  • With 16" Conventional Spare Tyre
  • With Full Wheel Cover
  • Non Locking Lug Nuts
  • Less Engine Pre-Heater
  • Less Engine Idle Shutdown Timer
  • Less MPH Engine Governor
  • Cold Start -29 Deg C
  • Standard Electric Starter Motor
  • With Remote Starter
  • 50 State Emission Requirements
  • Front Axle Rating-Maximum
  • With Brake Dust Shield
  • 3.31
  • Rear Axle Limited Slip Differential
  • 3.5L V6 GTDI
  • With Mechanical Parking Brake
  • Power 4-Wheel Disc Vacuum Boost
  • Integrated Brake Control
  • Brakes-ESP/HLA/FBS
  • Normal Fuel Fill
  • For Unleaded Fuel
  • With Speed Control
  • 390M
  • 6 Speed Automatic Trans (6R80)
  • Transit V363
  • (+)"USA"
1 - 1 of 1 Posts
