Structural compromise after drilling boron steel?
446 11
Ok, I HAVE used the search function on this.
I want to install a length of l-track near the driver side ceiling of my van (between B and C pillars). There are two existing holes I've used for plus nuts, but I need a few more anchor points.
I've read what I can find on the unique joys of drilling the boron steel - but my question is if this is a poor idea on its face? Since the Transit is a unibody frame, am I compromising the integrity of the vehicle putting drill holes in the reenforced zones?
Am I overthinking this?
1 - 12 of 12 Posts
You will probably strengthen things if any.
The main problem with drilling boron steel is from the risk of it corroding as a result. That's all down to removing burrs and priming the hole after drilling.
You should be OK with Riv/PlusNut sized holes to support L-track. Many of us have done exactly what you are looking to do, without issue (apart from the joy of drilling boron steel lol).
If you think about what's allowed in home construction, a maximum size hole in the center of a load carrying beam is allowed for wire and pipe.
All the holes in the transit rib are centered. A similar size hole, centered in the rib, greater than 2" from another hole or seam would seem reasonable. Don't hit your roof panel while drilling. Not much room for mistakes.
1 - 12 of 12 Posts
