Just read through this whole thread and am having the same issue with my van. Were you able to get an answer from the dealer?Expensive too!
I had the same issue with my 2015 transit 350 3.5L engine. My starting problem was random. My scanner would tell me that it was an open or short at the fuel pump. Ford did their diagnostic and said it was the fuel driver module. I argued with them because I had just replaced the module. The said that they could only find the problem if they could recreate the problem. After a week, they had no luck. I took the van home and drove it until it didn't start again. This time I replaced the fuel pump relay. All was good for a couple weeks. Out of frustration i took my pocket knife and tapped on the relay and the van started right up. The next time there was a problem was when I was actually driving. Pulled off the road and tapped on the relay again. The van started right up. I felt that I had actually discovered the source of the problem. Thinking there was some sort of loose connection, I took a small screwdriver and carefully bent the tabs in the socket to where I had to force the relay into the socket. That was 6 months ago and the problem has not returned. I also had the problems with water intrusion into the air filter and engine compartment. Ford wouldn't fix them, even though they were addressed in service bulletins. I bought my van used and because it was a commercial vehicle it was not covered by the service bulletins. Lesson learned! Hope this informatin helps!2015 Ford Transit 150 3.7 Flex
So same problem as everyone else, No start below 40F. The first thing I did after turning it over several times was check fuel pressure, disconnected supply line to fuel rail and put pressure gauge on it and got 57 psi. Oddly enough while pressure testing it(the way I set it up was just having the gauge to the supply line and did not have it pass through to the rail) it tried to crank with only residual fuel in the rail. Reconnected line and started right up, thought it was a weird hiccup until next morning when it was cold again no start. Ran diagnostics no faults, smoked system, no leaks, checked watched several streams of live data and nothing jumped out at me as being problematic besides it not starting. After spending several days of checking and rechecking I could not find an issue so just from everything I've read and just out of pure frustration I replaced fuel pump driver module. No fix, and now I'm down to brand new fuel pump, throttle actuator, it has already been serviced prior to this issue so it has brand new spark plugs air filter etc... Still no start, may not be related but found breather hose on driver side connector from valve cover to air intake boot(opposite side of the PCV) is sucking in oil and moisture. Have physically inspected every aspect of the powertrain system and I am stuck. Anyone??? help would be much appreciated
Never heard of TSB's not addressed due to being commercial sounds like a crock of **** to me.Ford wouldn't fix them, even though they were addressed in service bulletins. I bought my van used and because it was a commercial vehicle it was not covered by the service bulletins. Lesson learned! Hope this informatin helps!
avenge,Never heard of TSB's not addressed due to being commercial sounds like a crock of **** to me.
There are a bunch of TSB for the 2016 Transit, But this is for all engine types.avenge,
I had never heard or imagined that either. I ran a Carfax report with my VID#. There were no TBS's shown for the van. On the last page of the report the was note stating that Commercial vehicles might not be included in the TBS's. I had Ford check the VIN# and they also came up with no TBS's on my van. I even talked with the service manage and he had no explanation. All I can do is assume that is why the repairs were never done. The first six months of owning my van were very frustrating. I was very determined to fix the problems. Fortunately, with no help from Ford, I was able to solve the issues myself. I really enjoy my van now!
The issue isn't that the vehicle is a commercial vehicle(I was mistaken about that part of it), the problem with my van is that it was origonally sold to a rental company. Rental vehicles appear to be not approved for the repairs. That is probably why my VIN shows no recalls. My apologies. I still hope that my solution, to the starting problem, is helpful to someone.There are a bunch of TSB for the 2016 Transit, But this is for all engine types.
2016 Ford Transit Technical Service Bulletins
2016 Ford Transit Technical Service Bulletinswww.aboutautomobile.com
And there is no such thing as Commercial only because the Transit is listed as a commercial vehicle, It says Commercial right on my Title.
