I might try to set up my camper's electrical system so that the house battery can be used to start the engine if the starter battery dies.I'd suspect it is a little higher. On a frosty morning higher still. I'll throw my clamp meter on mine and see what I get. Just curious, why do you want to know?
Gotcha. I have wondered about using my house bank for the same. As it has a 100 amp BMS I guess I would connect the two and wait for a few minutes and then give it a shot starting.I might try to set up my camper's electrical system so that the house battery can be used to start the engine if the starter battery dies.
Not sure I follow you logic on this. Did you add a 20A manual toggle between the house battery and CCP?It took very little external boost the 2x the starter battery was dead enough to reset the clock to 12 AM and reset the trip odometer to zero.
There's a 20 amp manual toggle switch configured to allow the house battery to charge from the alternator through a CCP. It also allows the house battery to equalize with the starter battery. Its saved me from having to jump start. Have to be sure to move the switch to Off when attempting to start after allowing it to equalize or risk blowing the 60 A CCP fused link. An inline 50 A fuse might be wise between CCP & the house battery.
So your just using a basic 12V FLA charger to give the starter battery a boost? Would a 25A charger work?I just use a 120 vac to 12 vdc charger to move power.
Used it a few months ago to start my wife's car from my van's auxiliary electrical system.
The one I have is a 75 amp @12 volt IOTA and takes a 20 amp plug but they make smaller ones.
Yes, it's next to my seat belt buckle. Fasten the seat belt, flip the switch On. Unbuckle the seat belt, flip the switch Off. Need some juice in a dead starter battery, flip the switch On, wait a couple minutes, flip it back Off and turn the key.Not sure I follow you logic on this. Did you add a 20A manual toggle between the house battery and CCP?
I too use a 120 vac to 12 vac charger , I power mine from my generator , I take it that your powering yours from a invertor ?I just use a 120 vac to 12 vdc charger to move power.
Yes.I too use a 120 vac to 12 vac charger , I power mine from my generator , I take it that your powering yours from a invertor ?
I have done this exactly 1 time so far.So your just using a basic 12V FLA charger to give the starter battery a boost? Would a 25A charger work?
Thanks for explaining! My case would be similar, just for emergency use. If it took 10, 30, or even 60 min to transfer enough power, it's better than nothing!I have done this exactly 1 time so far.
The reason is that my wife's car would not start, she was stranded late at night and I could not find my jumper cables.
I had the 75 amp charger already wired with heavy duty jumper cables for one of the test stands I use for van work, so I used it.
Jump starting a car from an operating car means that you are really using its (alternator) + (starter battery) to power the starter of the inoperable vehicle.
What I did was partially recharge the inoperable vehicle starter battery using the 12 volt charger. Essentially charging it enough to run the starter, as the charger cannot by itself provide this amount of power. This takes time, the smaller the charger amps, the longer it takes.
A quick estimate of what is needed, using the OP's measurements:
(200 amps) x ( ~ 5 seconds) ~ 1000 amp-seconds @12 volts
(1000 amp-seconds @ 12 volts) / (25 amp charger) ~ 400 seconds ~ 7 minutes minimum to move enough power.
Maybe double that estimate to be safe ????
