looks like having dish mounted pointing Straight Up and no dish movement is now working -
from what I have seen having good connection is also possible while van is moving -
Im going to mount dish on roof in Flat position -
going to leave dish stock except Unplug motors so dish wont move -
dish will be be removed from roof and use stock legs for ground placement -
im camped in the desert so have to use materials on hand wood -
should be a easy to build -
in Every video I watched Power Grinders were used - not smart -
in video below one man uses a drill bit to cut hole in plastic - Dont Do This -
A Much Easier and Way Better way is to cut plastic with a Soldering Iron -
Soldering Iron will melt plastic and cut any shape hole you need Safely with little
chance of damaging board -
also there is No plastic chips all over inside -
video where man is cutting dish and making flat cases look pretty well made -
he is making box real strong for use on dune buggies -
case looks worth the money if you need this strong -
I will post some pictures and a DIY info on what I end up doing -
also have a few more videos on what others have done -
Dont use a drill like this man
