Light weight ceiling
My quest for a light weight ceiling began with a failed attempt using "wacky plywood" or bending board. It's a 3/8" plywood that bends very easily in one direction. After lifting a sheet and bracing to the roof like it was a sheetrock job, it was deemed heavy and too flexible. On to 1/8 Luan idea.
I had read that Luan might buckle or sag overtime and the edge between the wall and ceiling needed to be straight looking.
I installed upper walls that extended above the roof ribs. This allowed a strip of wood to be glued at the top of the wall. With the ceiling in place, the edges press up tight to this strip.
The bottom location for the strips was traced onto the side wall using a straight edge against the roof ribs. You can see the side panels are cut to fit the ribs and wire runs.
Five plusnuts were installed in each rib. One centerline, one outward each side about a foot to the next useful holes and the last on each edge about six inches from each wall. These holes (might also be slots) are existing. The plusnut was positioned so the tabs fell across the slot in an x. If you are using a tool with a long bolt, use some washers; you don't want to dent your roof.
Measurements
The width of the van bows slightly front to back and the roof is arched at the front, and further narrows. To transfer the width to the sheets, I used a measuring stick. At each roof rib, I took a wood strip. 3/16 thick, 3/4 wide and 70" long. The stick was placed against the side wall, arched tight to the rib, and trimmed to fit tight at the other end with puning shears. This stick, pushed tight against the rib, will hold itself in place due to the arch. This is the same thing with the panel. Push it up and it will hold in place. The end result is a set of sticks with the exact width at each rib.
Then I marked the center of each plusnut for each each rib stick. These are then used to transfer the measurements to sheet goods.
Sheet layout
All my sheets were run side to side, so I cut them to 70" long. I varied the width to get seams across the van at places of my choice, none of which were allowed to fall within six inches of a rib. [Instead, sheets were edge butted in free space using tabs for sheet alignment. This allowed the sheet to self support, rather than screwing down an edge.] Then each sheet was marked with a center line on the short axis. This centerline will cross each rib at the center plusnut marked on the rib stick. If you laid all your sheets out, edge to edge, using the centerline, and then placed each rib stick at each rib location along the centerline, you get the width by tracing the tips, and the location for each bolt hole. The first set of rib holes were drilled perpendicular to the centerline. After that rib sticks are laid out measuring off the previous holes or edge of sheet.
How lucky was I?
Every sheet was cut and drilled before install. Every one fit with minimum edge trimming with a block plane. Every hole lined up. Once the sheets were up, tab locations were marked with tape. There is a slight arch in the roof, so seam lines are tapered and need adjusting. Adjust fit, then drill holes and glue tabs. The front panel is a challenge. More arch equals more taper.
See post #4 above for how the last panel was constructed.
My head hurts. You?
